my 96 corolla 1.8L 7A-FE (155K miles) continues to oveheat. I am stymied and looking for any insight.
I replaced the water pump, radiator, 2 thermostats, 2 radiator caps.
Installed a new headgasket because of 'oily' look in the radiator fluid. No evidence of water in the oil. Also replaced the valve stem seals.
The car runs WODERFULLY with much more engine power.
For the overheating.....
I can leave the car idling 30 minutes without overheat.
I can drive over 10 miles @ 75 mph before the gauge rises above the center.
If I kept driving, all of the water steams out of the overflow tube.
I pressure tested the cooling system (radiator, hoses and block) to 18 PSI and the gauge holds study.
I removed the radiator hoses and thermostat and flushed the block with a garden hose - no apparent blockage.
Also flushed the radiator with the garden hose and the radiator flow seemed fine.
OK, I am about stuck - Looking for suggestions. It's personal now to get it fixed.
Thanks in advance
Thanks in advance
