just bass.umeshr85 said:
check your head unit manual or post it here for someone to advice as it may have a low pass filter, or check your amp for a "sub woofer" or "frequency" switch and if possible, set it to something like 60 or 80Hz.
just bass.umeshr85 said:is sound suppose to come through the subwooferS? or just bass?
mine has sound and bass, the sound is low though.
my subs are hooked up to the headunit, via rca's going to the amp.
huh?jeremiahfoote said:sound will also come through, if they are dual voice coil....
yeah, if it's not configured properly, you will. but not because it's a dual voice coil.jeremiahfoote said:you will hear voices come through the subs on a dual voice coil subwoofer.
and i don't even have to listen to them to tell you that if that's all he's using, it's probably close bo being the most horrible home sound system on the planet.jeremiahfoote said:and my friend actualy uses a set of dual voice 15" in his bedroom as his house speakers.
probably because you're passing treble through themjeremiahfoote said:i dunno... i just have 1 sub right now, i have went through 2 sets of 12"s a set of 15 and now i'm on my 1 15" with a 360 oz mag
yes, you can damage a subwoofer by passing treble through it.umeshr85 said:i do have an aftermarket head unit
and i can control the bass and treble from it
i dont mind that i can hear sound from the subs, but i dont want the sub to be damaged due to it.
i dont hear the voice from the inside, just the bass.
It features a 4 ohm 2” Parabolic RFL voice coil for 40% more power handling capabilities, a 60 oz. magnet, an oversized rubber surround, and a Poly Zirconium cone for 25% tighter and punchier bass.
any cheap fixes?
no, that's not what i'm saying at all. if you turn the treble down for the entire system all you'll get is a dull sound.umeshr85 said:you think if i lower the treble on the headunit it will go away, i usually keep the treble all the way up
didnt think about that
i'll see what happens tomorrow if i turn it down
Crossovers are not "brick walls" so they will still allow some higher/lower frequencies through (the amplitude depends on the crossover point/slope) so even with a low pass filter you will be able to hear some upper frequencies if you put your ear near the sub. Yes subs are designed to play "bass" however contrary to some beliefs you cannot damage a sub playing higher frequencies through it. Also, depending on the parameters a sub will naturally "roll off" higher frequencies at some point anyway and even if you played it full range the worst case scenario is it would just sound like a$$.umeshr85 said:i do have an aftermarket head unit
any cheap fixes?
Delay_FTB said:Where did everyone else go? You youngn's worry me...:disappoin
I'll post up later.
Agreed. Had 2 15w6s in my last car. Amps were hooked into the subout on the headunit, settings were right on the headunit, and both amps were tuned correctly, but still you could hear the music lightly with the bass. It happens.Mr Marv said:Crossovers are not "brick walls" so they will still allow some higher/lower frequencies through (the amplitude depends on the crossover point/slope) so even with a low pass filter you will be able to hear some upper frequencies if you put your ear near the sub. Yes subs are designed to play "bass" however contrary to some beliefs you cannot damage a sub playing higher frequencies through it. Also, depending on the parameters a sub will naturally "roll off" higher frequencies at some point anyway and even if you played it full range the worst case scenario is it would just sound like a$$.
BTW, the major benefit to dual voice coil subs is flexibility in wiring.
