the sunroof on my 91 no longer operates correctly. the motor itself is fine, but the middle (idler) gear in the sunroof transmission is stripped. there are no markings on the transmission housing or on the gear to indicate part numbers.
what i'm calling the "transmission" is the assembly that is bolted to the output end of the denso motor. it also has the exterior limit switches attached to it. the version used in the 91 has three gears, while most other toyota models used a 2-gear version.
in searching, i come up with entire assemblies, ie, the motor, wiring leads, and 3-geared sunroof "transmission", but never the actual gears. the gear is plastic with a brass center hub. it stripped, likely from the roof not being lubricated by the PO, and the two gears it meshes with are all metal. it has 35 teeth, too.
i know it's a longshot, but has anyone had any luck sourcing this gear?
wally
wally
