1 - 20 of 52 Posts
84 and 89 Supra
Hey Folks;
I'm sure most of you know that Whiteline Pricing went up 11% on May 1st 2007; well now SuperPro is following. On September 1st 2007 Superpro Pricing is going up 11% as well.
PARTS
MK3 Supra
Front Adjustable Sway bar: $181usd
Rear Adjustable Sway bar: $177usd
SuperPro SPF1443K Front Control Arm Lower - Inner Bushing: $113.45
SuperPro SPF1576K Front Control Arm Upper - Inner Bushing: $62.69
MK4 Supra Products
SuperPro SPF1403K Front Control Arm Lower - Front Bushing: $47.74
SuperPro SPF1650K Front Control Arm Lower - Front Bushing: $49.45
SuperPro SPF1404K Front Control Arm Lower - Rear Bushing: $51.06
SuperPro SPF1651K Front Control Arm Lower - Rear Bushing: $55.08
SuperPro SPF1352K Front Control Arm Upper - Inner Bushing: $57.68
SuperPro SPF1474K Front Control Arm Upper - Inner Bushing: $84.95
SuperPro SPF1193K Steering Rack & Pinion Mount Bush Power Steering: $23.01
SuperPro SPF1922K Rear Control Arm Upper - Inner Bushing: $73.31
Whiteline 30mm Front Sway Bars (non Adjustable): $151.77
Whiteline 30mm Front Sway Bars (Adjustable): $171.80
Whiteline 20mm Rear Sway Bars (non Adjustable): $151.77
Whiteline 20mm Front Sway Bars (Adjustable): $171.80
87-91 Camry
Whiteline BTF91 4cyl 27mm Front Sway Bar (non Adjustable): $151.77 (threaded end bar- offroad only)
Whiteline BTR38 4cyl 18mm Rear Sway Bar (non Adjustable): $124.32
SuperPro SPF0511K Front Control Arm Lower - Inner Bushing $28.56
SuperPro SPF0329-24K Front Sway Bar Mount To Chassis Bushing $20.12
SuperPro SPF0329-24AK Front Sway Bar Mount To Chassis Bushing $20.12
SuperProSPF0329-24BK Front Sway Bar Mount To Chassis Bushing $20.12
SuperPro SPF0329-26AK Front Sway Bar Mount To Chassis Bushing $20.12
SuperProSPF0329-26BK Front Sway Bar Mount To Chassis Bushing $20.12
SuperPro SPF0329-26K Front Sway Bar Mount To Chassis Bushing $20.12
SuperPro SPF0329-27AK Front Sway Bar Mount To Chassis Bushing $20.12
SuperPro SPF0329-27BK Front Sway Bar Mount To Chassis Bushing $20.12
SuperPro SPF0329-27K Front Sway Bar Mount To Chassis Bushing $20.12
SuperPro SPF0321K Front Sway Bar To Lower Control Arm Bushing $28.77
SuperPro SPF1221K Rear Control Arm - Inner Bushing $22.45
SuperPro SPF1220K Rear Control Arm - Outer Bushing $21.11
SuperPro SPF0462-_ _K Rear Sway Bar Mount To Chassis Bushing $10.84
SuperPro SPF0823K Rear Trailing Arm - Bushing Kit $44.73
Dobinson SV20/21/22 Sedan/Wagon Front Lowering Springs: $124
Dobinson SV20/21/22 Sedan/Wagon Rear Lowering Springs: $124
Dobinson SV20/21/22 Sedan/Wagon Front Std Height Springs: $124
Dobinson SV20/21/22 Sedan/Wagon Rear Std Height Springs: $124
92-96 Camry
Whiteline BTR36 18mm Rear Sway Bar(non Adjustable): $124.32
Whiteline KSB566 Front Strut Tower Bar- alloy adjustable: $157.84
Whiteline 75500 sedan/wagon 25-40mm Front Lowering Spring: $126.41
Whiteline 78600A sedan 25-40mm Rear Lowering Springs: $126.41
Whiteline 78617 wagon 25-40mm Rear Lowering Springs: $126.41
Whiteline KCA417 Front Camber Adjust Bolt Kit - 17mm: $62.45
Whiteline KCA322 Front Caster Adjust Kit - Control Arm: $81.65
Whiteline KCA415 Rear Camber Adjust Bolt Kit - 15mm: $62.45
SuperPro SPF2663K Front Control Arm Lower - Front Bushing $14.02
SuperPro SPF1265K Front Control Arm Lower - Rear Bushing: $26.74
SuperPro SPF1348K Front Engine Steady Bushing(4cyl):$20.76
SuperPro SPF2706K Front Engine Steady Bushing(6cyl):$35.35
SuperPro SPF1191K Front Steering Rack & Pinion Mount Bush Power Steering: $16.26
SuperPro SPF1132-_ _K Front Sway Bar Mount To Chassis Bushing (factory): $13.65
SuperPro SPF1105K Rear Control Arm - Outer Bushing: $54.38
SuperPro SPF2297-_ _K Rear Sway Bar Mount To Chassis Bushing (factory): $12.87
SuperPro SPF0823K Rear Trailing Arm - Bushing Kit:$44.73
Dobinson V10 Sedan/Wagon Front Lowering Springs: $124
Dobinson V10 Sedan/Wagon Rear Lowering Springs: $124
Dobinson V10 Sedan/Wagon Front Std Height Springs: $124
Dobisnon V10 Sedan/Wagon Rear Std Height Springs: $124
Dobinson V10 Sedan/Wagon Front Raised Height Springs: $124
Dobinson V10 Sedan/Wagon Rear Raised Height Springs: $124
Dobinson V10 V6 Front Super Low Springs: $124
Dobinson V10 V6 Rear Super Low Springs: $124
97-02 Camry
Whiteline BTF38 24mm Front Sway Bar(non Adjustable) $124.32
Whiteline BTR39 20mm Rear Sway Bar(non Adjustable) $124.32
Whiteline BTR39Z 20mm Rear Adjustable Sway Bar: $154.55
Whiteline Front Strut Tower Brace - allow adjustable: $140.67
Whiteline 4cyl Sedan 25-40mm Lowering Springs Front (73120): $126.41
Whiteline 4cy Sedan 25-40mm Lowering Spring Rear (78600A): $126.41
SuperPro SPF1265K Front Control Arm Lower - Rear Bushing $26.73
SuperPro SPF1191K Front Steering Rack & Pinion Mount Bush Power Steering $16.26
SuperPro SPF1132-_ _K Front Sway Bar Mount To Chassis Bushing (factory) $13.65
Dobinson V20 Sedan/Wagon Front Lowering Springs: $124
Dobinson V20 Sedan/Wagon Rear Lowering Springs: $124
Dobinson V20 Sedan/Wagon Front Std Height Springs: $124
Dobinson V20 Sedan/Wagon Rear Std Height Springs: $124
Dobinson V20 Sedan/Wagon Front Raised Height Springs: $124
Dobinson V20 Sedan/Wagon Rear Raised Height Springs: $124
Dobinson V20 6cyl Sedan Front Super Low Springs: $124
Dobinson V20 6cyl Sedan Rear Super Low Springs: $124
72-77 Celica
Whiteline TA20/TA22 BTF10 22mm Front Sway Bar(non-adjustable): $122.07
Whiteline TA20/TA22 BTR17 18mm Rear Sway Bar(non-adjustable): $122.07
Whiteline TA23/RA23-28 BTF25 24mm Front Sway Bar(non-adjustable): $95.58
Whiteline TA23/RA23-28 BTF25Z 24mm Front Sway Bar(adjustable): $171.79
Whiteline TA23/RA23-28 BTR17 18mm Rear Sway Bar(non-adjustable): $122.07
Whiteline TA23/RA23-28 BTR17Z 18mm Rear Sway Bar(adjustable): $171.79
Whiteline RA,TA22 KSB601 Front Roll Centre Adjuster: $140.67
Whiteline RA,TA22 KPR010 Rear Off Car Adjustable Panhard Rod: $82.97
Whiteline RA23-28, TA23 KSB601 Front Strut Tower Brace –alloy Adjustable: $140.67
Whiteline RA23-28, TA23 KCA363 Front Roll Centre Adjuster: $164.52
Whiteline RA23-28, TA23 KPR010 Rear Off Car Adjustable Panhard Rod: $82.97
78-81 Celica
Whiteline RA40/60 Liftback BTF25 24mm Front Sway Bar(non-adjustable): $95.59
Whiteline RA40/60 Liftback BTR25R 18mm Rear Sway Bar(non-adjustable): $122.07
Whiteline RA40 Coupe BTF25 24mm Front Sway Bar(non-adjustable): $95.59
Whiteline RA40 Coupe BTR25 24mm Front Sway Bar(non-adjustable): $122.07
Whiteline RA40 KSB601 Front Strut Tower Brace – allow adjustable: $140.67
Whiteline RA40 KCA362 Front Roll Centre Adjust: $198.32
Whiteline RA40 KPR009 Off Car Adjustable Panhard Rod: $82.97
82-85 Celica
Whiteline RA60 Coupe BTF23 24mm Front Sway Bar(non-adjustable): $122.07
Whiteline RA60 Coupe BTR25R 18mm Rear Sway Bar(non-adjustable): $122.07
Whiteline RA65/SF63 Liftback BTF30 27mm Front Sway Bar(non-adjustable): $151.77
Whiteline RA60-65;SA63 KCA363Front Roll Centre Adjuster: $164.62
Whiteline RA60-65;SA63 KPR009 Off Car Adjustable Panhard Rod: $82.97
86-89 Celica
Whiteline ST162 FWD BTF60 22mm Front Sway Bar(non-adjustable): $151.77
Whiteline ST162 FWD BTR32 18mm Rear Sway Bar(non-adjustable): $122.07
Whiteline ST165 AWD-Turbo BTF73 27mm Front Sway Bar(non-adjustable): $151.77
Whiteline ST165 AWD-Turbo BTR78 20mm Rear Sway Bar(non-adjustable): $151.77
Whiteline ST165 AWD-Turbo BTR78Z 20mm Rear Sway Bar(adjustable): $171.79
Whiteline ST165 KSB612 Front Strut Tower Brace –adjustable alloy: $150.96
Whiteline ST165 KSB613 Rear Strut Tower Brace –adjustable alloy: $140.73
89-94 Celica – some bushings not for all models…please ask if you have any questions.
SuperPro SPF1435K Front Control Arm Lower - Front Bushing: $39.60
SuperPro SPF1320K Front Control Arm Lower - Rear Bushing: $35.60
SuperPro SPF1335-_K Front Sway Bar Mount To Chassis Bushing: $8.43
SuperPro SPF2730K Rear Control Arm - Inner Front Bushing: TBD
SuperPro SPF1221K Rear Control Arm - Inner Rear Bushing: $22.45
SuperPro SPF2263K Rear Control Arm - Outer Bushing: $62.96
SuperPro SPF2731K Rear Control Arm - Outer Bushing: TBD
SuperPro SPF2264K Rear Control Arm Lower - Inner Front Bushing: $45.70
SuperPro SPF2265K Rear Control Arm Lower - Inner Rear Bushing: $44.06
SuperPro SPF0462-_K Rear Sway Bar Mount To Chassis Bushing: $10.84
SuperPro SPF0823K Rear Trailing Arm - Bushing Kit: $44.73
Whiteline ST184 FWD BTF62 27mm Front Sway Bar(non-adjustable): $151.77
Whiteline ST184 FWD BTR62 18mm Rear Sway Bar(non-adjustable): $112.06
Whiteline ST185 AWD-Turbo BTR29 20mm Rear Sway Bar(non-adjustable): $112.06
Whiteline ST185 AWD-Turbo BTR29Z 20mm Rear Sway Bar(adjustable): $151.77
Whiteline ST165 KSB546 Front Strut Tower Brace –adjustable alloy: $150.96
Whiteline ST165 KSB547 Rear Strut Tower Brace –adjustable alloy: $140.67
Dobinson ST184;ST185 Turbo Front Lowering Springs: $124
Dobinson ST184;ST185 Turbo Rear Lowering Springs: $124
Dobinson ST184;ST185 Turbo Front Standard Height Springs: $124
Dobinson ST184;ST185 Turbo Rear Standard Height Springs: $124
Dobinson ST184;ST185 Turbo Front Super Low Springs: $124
Dobinson ST184;ST185 Turbo Rear Super Low Springs: $124
95-98 Celica
Whiteline BTF78 22mm Front Sway Bar(non-adjustable): $151.77
Whiteline BTR82 20mm Rear Sway Bar(non-adjustable): $151.77
Whiteline BTR82Z 20mm Rear Sway Bar(adjustable): $151.77
Dobinson ST205;ST204 Front Lowering Springs: $124
Dobinson ST205;ST204 Rear Lowering Springs: $124
Dobinson ST205;ST204 Front Standard Height Springs: $124
Dobinson ST205;ST204 Rear Standard Height Springs: $124
99-04 Celica
SuperPro SPF0996K Front Control Arm Lower - Inner Front Bushing: $21.39
SuperPro SPF2085K Front Control Arm Lower - Inner Rear Bushing: $85.94
SuperPro SPF2086K Front Control Arm Lower - Inner Rear Bushing: $85.94
SuperPro SPF2087K Front Control Arm Lower - Inner Rear Bushing: $85.94
SuperPro SPF2088K Front Control Arm Lower - Inner Rear Bushing: $85.94
Whiteline BTF72 24mm Front Sway Bar(non-adjustable): $112.06
Whiteline BTR74 20mm Rear Sway Bar(non-adjustable): $112.06
Whiteline BTF72Z 24mm Front Sway Bar(adjustable): $151.77
Whiteline BTR74Z 20mm Rear Sway Bar(adjustable): $151.77
Whiteline BTR74XZ 22mm Rear Sway Bar(adjustable): $171.80
Whiteline KSB522 Front Strut Tower Brace – Alloy Adjustable: $140.67
Whiteline KSB707 Front Lower Control Arm Brace: $104.60
Whiteline KCA364 Rear Roll Couple Adjust Kit: $123.40
Dobinson Front Lowering Springs: $124
Dobinson Rear Lowering Springs: $124
Dobinson Turbo Front Standard Height Springs: $124
Dobinson Turbo Rear Standard Height Springs: $124
MX73 Twin Cam IRS Cressida
Whiteline BTR59 16mm Rear Sway Bar(non-adjustable): $112.06
Dobinson Front Lowering Springs: $112
Dobinson Rear Lowering Springs: $112
Dobinson Front Standard Height Springs: $112
Dobinson Rear Standard Height Springs: $112
SuperPro SPF0509K Front Control Arm Lower - Inner Bushing:
SuperPro SPF2755SK Front Sway Bar Link Bushing Kit
SuperPro SPF1319-_ _K Front Sway Bar Mount To Chassis Bushing
SuperPro SPF0427K Rear Panhard Rod To Chassis Mount Bushing
SuperPro SPF0963K Rear Panhard Rod To Diff Mount Bushing
SuperPro SPF2178-16K Rear Shock Absorber Lower Bushing
SuperPro SPF0903K Rear Sway Bar Link Bushing Kit
SuperPro SPF1446-_ _K Rear Sway Bar Mount To Chassis Bushing
SuperPro SPF0827K Rear Trailing Arm Lower Bushing All
SuperPro SPF0826K Rear Trailing Arm - Upper - Bushing All
MX83 Cressida
Whiteline BTR30 16mm Rear Sway Bar(non-adjustable): $112.06
Dobinson Front Standard Height Springs: $124
Dobinson Rear Standard Height Springs: $124
SPF1324K Rear Control Arm Lower - Outer Bushing
AE86 Corolla
Whiteline KSB519 Adjustable Strut Tower Brace: $140.67
Whiteline KCA363 Roll Centre Adjust Kit: $164.61
Whiteline 71713 Front Lowering Springs: $126.41
Whiteline BTF35Z Adjustable 24mm Front Swaybars: $172.73
Whiteline BTF35 Non-Adjustable 24mm Front Swaybars: $151.77
Whiteline BTF35X Non Adjustable 27mm Front Swaybars: $171.80
Whiteline KPR010 Rear Panhard rod: $82.95
Whiteline KTA111 Rear Adjustable Traction Bracket: $124.26
Whiteline KTA120 Rear Adjustable Lower Trailing Arm: $183.07
Whiteline KTA110 Rear Adjustable Upper Trailing Arm: $183.07
Whiteline 71210 Rear Lowering Springs: $126.41
Whiteline BTR25Z Rear Adjustable 18mm Rear Swaybar: $172.73
Whiteline BTR25R Rear Swaybar: $171.80
SuperPro SPF0509K Front Control Arm Lower Inner Bushings: $19.76
SuperPro SPF0699-19K Front Strut Bar to Chassis mount Bushings: $18.5
SuperPro SPF2092BK Front Sway Bar Link Bushings: $9.96
SuperPro SPF1450-_ _K Front Sway Bar to Chassis Bushing: $9.36
SuperPro SPF1827K Panhard Rod Bushings: $11.63
SuperPro SPF0427K Panhard Rod to Chassis Mount Bushings: $14.22
SuperPro SPF0963K Panhard Rod to Diff Mount Bushings: $11.61
SuperPro SPF0290K Sway Bar Link Lower Bushings: $30.67
SuperPro SPF0903-4K Sway Bar Links Upper Bushings: $7.32
SuperPro SPF0980K Trailing Arm Lower Bushings: $60.14
SuperPro SPF0980K Trailing Arm Upper Bushing: $60.14
AE82 Corolla
Superpro SPF0326K Front Control Arm Lower - Front Bushing: $21.28
Superpro SPF1360K Front Control Arm Lower - Rear Bushing: $38.15
Superpro SPF1361K Front Control Arm Lower - Rear Bushing: $33.42
Superpro SPF1362K Front Control Arm Lower - Rear Bushing: $33.42
Superpro SPF1362AK Front Control Arm Lower - Rear Bushing: $33.42
Superpro SPF0903K Front Sway Bar Link Bushing Kit: $12.86
Superpro SPF1216K Rear Control Arm - Inner Bushing: $29.01
Superpro SPF0825K Rear Control Arm - Outer Bushing: $36.83
Superpro SPF0280K Rear Sway Bar Link Lower Bushing: $14.12
Superpro SPF0903-4K Rear Sway Bar Link Upper Bushing: $10.63
Superpro SPF0199-_ _K Rear Sway Bar Mount to Chassis Bushing: $11.00
Superpro SPF0823K Rear Trailing Arm - Bushing Kit: $14.04
Whiteline KSB533 Front Adjustable Brace-strut tower: $140.54
Whiteline KCA318 Front Caster Adjustable kit - control arm: $38.53
Whiteline 70389 Front Spring-coil lowering kit - Control. Twin cam: $130.39
Whiteline 72409a Front Spring-coil lowering kit - Control. excl Twin cam: $130.39
Whiteline BTF65 20mm Front Adjustable Swaybar: $154.55
Whiteline BTF70 22mm Front Swaybar: $154.55
Whiteline KSB540 Rear Strut Tower Brace- alloy Adjustable: $140.54
Whiteline KCA412 Rear Camber Adjustable bolt kit-12mm +/- 1.5 deg: $54.78
Whiteline 78606 Rear Spring-coil lowering kit - Control: $130.39
Whiteline BTR65Z Rear Adjustable Swaybar: $174.95
Whiteline BTR65 Rear Swaybar: $124.30
AE101; AE102, AE112 94- 11/01 Corolla
Superpro SPF0996K Front Control Arm Lower - Inner Front Bushing: $23.80
Superpro SPF1900K Front Control Arm Lower - Rear Bushing: $87.60
Superpro SPF1901K Front Control Arm Lower - Rear Bushing: $87.60
Superpro SPF1902K Front Control Arm Lower - Rear Bushing: $87.60
Superpro SPF2298K Front Control Arm Lower - Rear Bushing: $30.75
Superpro LP8130 Front Sway Bar Link Complete Rod OE Replacement: $33.10
Superpro SPF0832-_ _K Front Sway Bar Mount to Chassis Bushing: $ 12.51
Superpro SPF1947K Rear Control Arm - Bush Kit: $72.00
Superpro LP8001 Rear Sway Bar Link Complete Rod OE Replacement: $30.33
Superpro LP8124 Rear Sway Bar Link Complete Rod OE Replacement: $25.06
Superpro SPF0613-_ _K Rear Sway Bar Mount to Chassis Bushing: $13.24
Whiteline KSB583 Adjustable Front Strut Brace-strut: $150.83
Whiteline KCA415 Front Camber Adjustable bolt kit-15mm: $62.39
Whiteline KCA340 Front Caster Adjustable kit - to 7/95 with horiz mount: $58.01
Whiteline 70389 Front Spring-coil lowering kit - Control: $130.39
Whiteline KCA412 Rear Camber Adjustable bolt kit-12mm: $54.78
Whiteline 70416 Rear Spring-coil lowering kit - Control: $130.39
Whiteline BTR71Z 18mm Rear Swaybar- Adjustable: $154.55
Whiteline BTR71 18mm Rear Swaybar: $124.29
Whiteline BTR71XZ 20mm Rear Swaybar-X h/duty Blade Adjustable: $174.95
Whiteline BTR71X 18mm Rear Swaybar: $124.29
AE110-112 5/99 – 11/01
Superpro SPF0832-_ _K Front Sway Bar Mount to Chassis Bushing: $12.51
Whiteline KSB583 Front Adjustable Strut Tower Brace-strut tower: $150.83
Whiteline 83107 Front Spring-coil lowering kit: $130.39
Whiteline BTF82 22mm Front Swaybar: $124.29
Whiteline 83108 Rear Spring-coil lowering kit: $130.39
Whiteline BTR71Z 18mm Rear Swaybar Adjustable: $154.55
Whiteline BTR71XZ 20 mm Rear Swaybar Adjustable: $174.95
Whiteline BTR71X 20mm Rear Swaybar: $124.29
Corolla ZE120 Series 8/00-06
Whiteline KSB603 Front Adjustable Brace-strut tower: $140.54
Whiteline KCA412 Front Camber adj bolt kit-15mm: $54.78
Whiteline 73205 Front Spring-coil lowering kit: $130.39
Whiteline BTF72Z 24mm Front Adjustable Swaybar excl ZZE123: $154.55
Whiteline BTF85Z 24mmFront Adjustable Swaybar-h/duty ZZE123 only: $pm if interested
Whiteline BTF72 Front 24mm Swaybar excl ZZE123: $124.29
Whiteline BTF85 24mm Front Swaybar ZZE123 only: $pm if interested
Whiteline 73206 Rear Spring-coil lowering kit excl wagon: $130.39
Whiteline BTR77 22mm Swaybar-heavy: $154.60
AW11 MR2
Whiteline Control Front Lowering Spring(80337): $128.76
Whiteline Control Rear Lowering Springs(80354): $128.76
Whiteline BTF20Z 20mm Front Adjustable Swaybar: $172.73
Whiteline BTF20 20mm Front Swaybar(non adjustable): $122.72
Whiteline BTR64 16mm Rear Swaybar(non adjustable): $152.60
Whiteline BTR64Z 18mm Rear Adjustable Swaybar: $152.60
SuperPro SPF2781K Front Control Arm Lower - Inner Front Bushing: please inquire
SuperPro SPF2782K Front Control Arm Lower - Inner Rear Bushing: please inquire
SuperPro SPF2092B-4K Front Sway Bar Link To Lower Arm Bushing: $6.35
SuperPro SPF2399-_ _K Front Sway Bar Mount To Chassis Bushing: $9.72
SuperPro SPF2396K Rear Control Arm Lower - Inner Bushing: please inquire
SuperPro SPF2397K Rear Control Arm Lower - Outer Bushing: please inquire
SuperPro SPF2400-_ _K Rear Sway Bar Mount To Chassis Bushing: $12.79
SuperPro SPF2395K Rear Toe Control Arm - Inner Bushing: please inquire
SuperPro SPF2398K Rear Trailing Arm Lower Bushing All: please inquire
SW20 MRS
Whiteline KCA415 Front Camber Adjustment Bolt Kit: $61.60
Whiteline KCA415 Rear Camber Adjustment Bolt Kit: $61.60
Whiteline 80343 Control Front Lowering Springs: $128.76
Whiteline 80391 Control Rear Lowering Springs: $128.76
Whiteline BTF24Z 20mm Front Adjustable Swaybar: $152.60
Whiteline BTF24 20mm Front Swaybar (non-adjustable): $152.60
Whiteline BTR28Z 19mm Rear Adjustable Swaybar: $152.60
Whiteline BTR28 Read Swaybar (non adjustable): $152.60
SuperPro SPF1330-12K Front Control Arm - Inner Bushing: $30.31
SuperPro SPF1332K Front Strut Bar To Chassis Mount Bushing: $28.71
SuperPro SPF2092BK Front Sway Bar Link Bushing Kit: $9.96
SuperPro SPF0660-_ _K Front Sway Bar Mount To Chassis Bushing: $12.39
SuperPro SPF2377-_ _K Front Sway Bar Mount To Chassis Bushing: $11.73
SuperPro SPF1330-14K Rear Control Arm Lower - Inner Bushing: $30.31
SuperPro SPF0729-2K Rear Engine, Cushion, Front Stabilizer: please inquire
SuperPro SPF0661-_ _K Rear Sway Bar Mount To Chassis Bushing: $11.68
SuperPro SPF2378-_ _K Rear Sway Bar Mount To Chassis Bushing: $9.72
SuperPro SPF0823-4K Rear Trailing Arm - Front Bushing: $28.70
SuperPro SPF0699-22K Rear Trailing Arm - Rear Bushing: $18.58
ZZW30 MRS
Whiteline 72232 Front Control Lowering Springs: $128.76
Whiteline 73233 Rear Control Lowering Springs: $128.76
Whiteline BTF81Z 22mm Front Adjustable Swaybar: $172.73
Whiteline BTF81 22mm Front Swaybar (non-adjustable): $122.72
Whiteline BTR84Z 18mm Rear Adjustable Swaybar: $152.60
Whiteline BTR84 18mm Rear Swaybar: $112.72
SHIPPING
Email me what you are interested in and I will respond with a quote: [email protected]
Do NOT send PM as I can't keep track of all the PM's I get...email is better. PM's with questions will be ignored.
PAYMENTS
paypal +2%: I really HATE doing this but I’m taking a pounding on paypal fee’s on these group buys. The parts are already at rock bottom prices during group buys so this will be the norm for all future group buys for me.
address = [email protected]
Money Order/Email Money Transfer/Cash: Email me for details…email address is in my sig
Please ensure your payment title is: 2007 Superpro Rear Bushing Groupbuy Payment
Also ensure in your payment you include:
EXACTLY what parts you are paying for
Your Forum Name
If you do not follow that format your payment will be immediately refunded; if you miss the deadline because of that I will not be responsible.
Deadline
Due to the complexity of the situation with the pricing increase the pricing will only last until August 30th. The part will be available after that but pricing will be much higher.
QUESTIONS?
Please feel free to post here or email me…do NOT pm me. Any PM’s will be ignored; it is just too much to manage business concerns via PM.
I need a whiteline front sway bar for a 2003 toyota solara v6.
you do not have it on the list, but the code is BTR85. double check this to see if it is for the right application.
i also need sway bar links. im not sure if it is for the front or rear. if they make a set for front and rear, then ill take both.
-mark
84 and 89 Supra
Sorry for the major delay; this weekend was the Toronto Supra Club's 12 Anniversary Meet and I'm an organizer.
Your part is $122.29; what is the chassis code for your vehicle. The parts listing is for a US Built Camry and need to ensure your Solara Chassis is the same. The part is in stock in the US warehouse and shipping is $20.
The bars do not come with endlinks so your factory ones must be re-used...this is done to keep the cost of the bars down.
84 and 89 Supra
Discussion Starter #7
Your chassis code is MCV20; but there is no listing for that chassis with any of the whiteline catalogs. My best recommendation is to go to the Solara section in this forum and ask the people there which year Camry bar fits your car. There is no listing for the Solara on whitelines catalog so neither they or I can guarantee a fitment. I'm sure this has been done on the Solara before...I will try to do a search myself and see what I can find but it would be a good idea to check yourself.
intrested in the following parts shipped to 96826. need a quote
84 and 89 Supra
Discussion Starter #11 (Edited)
Sorry man...didn't even see the post was updated :(. Shipping for those 3 is going to be $16.
So your total will be: $96.23...includes parts; shipping and paypal fees.
I realize it's my screw up but I'm going to need payment by this afternoon in order to honour those prices...i apologize :(.
On my way to spool faster
GT4 & Turbo Tercel
Hi, I am new on this forum. I need some rear bushings for my 1990 Celica GT-4. I need ALL of them, that means the ones for the three arms attached to the knuckle. Front/rear, inner outer, all of them.
Please tell me what I need to buy from you
Thanks,
Martin
84 and 89 Supra
Discussion Starter #13
Thanks,
Martin
Martin;
these are the bushings you are going to need with the associated pricing:
These ae the only bushings available for the ST185 from superpro; there are also swaybar to chassis mount bushings but if you ever upgrade your bars you get those so kind of pointless buying those.
That pricing unfortunately increase when the warehouse closed today; there is a very very small chance I might be able to get the 'old' pricing but it will have to be soon.
If you have any questions fire me off an email: george 'at' raptorracing 'dot' com.
I realize it's my screw up but I'm going to need pricing by this afternoon in order to honour those prices...i apologize :(.
where do i sent payment to & how long will it take to receive items. let me know by pm or post on here
GT4 & Turbo Tercel
raptorracing said:
Martin;
Are that the bushings for the rear suspension, because I would only buy for the rear.
That sounds to me like bushings for the front suspension.
Can you put the light into that for me, please.
I want to buy the minimum o stuff I need to. I think the number of bushings I need to replace to have all the rear suspension new, is 12 bushings overall.
Thanks,
Can't wait!
Martin
Hi george..
I have a 1989 Toyota Corolla GTS ae92 {chasis code} USDM. And i am looking for the rear suspension bushings. I want all of them. My ae92 it's got the Rear Disc Brake suspension.
They are 3 bars {suspension arms} for each side. Two facing perpendicular and one paralell to the car. Total 6 . In my repair manual they call the paralell ones .. STRUT ROD, and the perpendicular ones SUSPENSION ARMS. I want a whole package that will include the bushings for both ends of all the suspension arms/strut rods.
Sorry for being repetitive and giving so much information, You probably know all that but i want to make sure that i get the right parts the first time :) .
Please let me know the total price of the bushings and shipping to 34741 {Florida}.
Thanks a lot, i sent a copy of this post to your email [email protected] just in case.
Once again Thanks a lot.
84 and 89 Supra
Discussion Starter #17
Tavalon...payment info is in the first post....you can't miss it. In regards to how long it will take: SPF1219K is not in stock and it would take a minimum of 45 days to get in.
Thanks,
Can't wait!
Martin
Martin...sorry I didn't read where you just wanted the rear. So remove those 2 products from the list...all of the other bushings are in stock and I can have them shipped to my US address and pick them up in the next couple of weeks.
For both of you; there is a very slim chance that I can get you in on the pricing above but I would need payment before tuesday morning. Anytime after that and pricing goes up 11% as mentioned in the group buy.
If you guys have any more questions please send me an email: george 'at' raptorracing 'dot' com. I will not have a lot of time to come on this forum till then.
AE92AFDX; this payment deadline applies to you too...I will look at what's available and let you know later tonight.
payment sent in amount of $96.23
GT4 & Turbo Tercel
Hi, thanks for the precision,
I will take those parts:
That makes a total of: 197.45$ US
Can you send me the total price I have to pay to you, please, and then I will send you my payment.
Thanks a lot,
Martin
GT4 & Turbo Tercel
Celica ST185 rear bushings
Thanks a lot,
Martin
1 - 20 of 52 Posts
