1 - 4 of 4 Posts
hello i have a 06 as im approaching a stop about when im at 10 mph while braking the trans seems like it surges me forward i see the rpms go up to 1500 then as im slowing down the rpms go down to normal 700-800rpm range, it happens evertime with or without the a/c on car has 31000 miles and i just got it any suggestions?
2009 Avalon Limited
IF you "just got it" Get back to the dealer and have them look it over..Still under the 36k mile warranty.
'07 Avalon Limited
'07 Avalon Ltd
There's a technical service bulletin that covers surging as you described it. The fix is to have the ECU reflashed. The car will no longer surge and the tranny shifts a lot better afterwards.
Read all about it here: http://www.toyotanation.com/forum/showthread.php?t=197136&highlight=transmission+reflash
Official PITA
Solara 'Vert & ES350
I was having that very same problem, disconcerting to say the least.
2 weeks ago when cleaning up battery terminals, noticed a fitting near the
air-cleaner assembly that looked like it should have a vac hose attached to it.
Looking around, lo & behold, I found a thin rubber hose that fit nicely on that
fitting. All the surging was suddenly GONE.
Before anything else, have a look under hood.
1 - 4 of 4 Posts
