first you need to find a different source for info,
It has nothing to do with altitude. you'd have to get a lot farther north for that.
It is because it is idling too fast. adjust the idle with the idle air bypass screw, it is the big flatblade screw on the top of the throttle. the black one with the spring is to adlust the A/C idle-up.
If you can not get the idle to come down to spec you'll need to find out why, and there could be several causes including but not limited to a sticking auxillary air valve, incorrectly adjusted throttle stop, ruptured diaphram in the
A/C idle up valve, etc....
