If your sway bar is on then it will prevent the a-arms from flexing seperate (to an extent) There is simply not enough force to twist the torsion bar enough.
If you want to flex it - Jack up the opposite sided rear tire and place a jackstand under it, then jack up the front tire.
p.s shocks have little or nothing to do with how hard it is to compress suspension
