1 - 6 of 6 Posts
Hi i been trying to find an Eibach suspension for my 1990 AE92 COUPE. Eibach has discontinued the suspension Where could i find this suspension or is there any other i can used from any other rolla thats newer???
89' SR5
Are you looking for a coil over kit or what? You can try white line, they made my rear anti-sway bar. Ebay is usually a good source of knock off parts, so next best thing to Eibach but no brand name and way less money.
1991 Toyota Corolla,
B&G makes lowering springs for these cars which I've heard good things about. Sounds like you want a good quality setup. I did too so I went with Fortune Auto 500 coilovers. They're build to order by hand, and you can purchase upgrades, customize spring rates, yadda yadda. Check em out, I'm really happy with mine and I've got about 25,000 miles on mine with no issues.
This is strange to read... that Eibach has discontinued making springs. However, I have been using coilovers for the better part of 8 years and replaced my setup 3 times - due to very bad roads and a 20V engine swap, and perhaps not the best spring/shock combo.
I've been using Ground Control coilover springs and KYB shocks. Eibach supplies these springs and in conjunction with the sleeves from Ground Control, you can have stock ride height or lower by 2.5" -front and rear. I've not had a problem locating these and buying them. They cost on average US $400 shipped. If you have good roads, maybe they will last you a lot longer than mine, and the performance is outstanding. No leaning and swaying AT ALL on 15" wheels. You can nail the accelerator into a corner, get uniform wheelspin on both tyres, better launches and improved stopping power as the hard springs do not compress easily when the car's weight is being thrown onto 1 side. If you are into racing, these improved effects will shave a fraction of a second off your times. Watch out for oversteer as turning response is also a lot quicker.
One more option you can look into is Gecko Coilovers which is a spring and shock combo. I've never used them before, but they are becoming increasingly popular, and price point may be an indication that it's not "cheap" in every sense. Gecko makes coilovers for all applications and there are claims that they provide versatility and handling options for even the big brands - like BMW, Mercedes-Benz, Audi, Lexus, etc..
· Senior TN Member
Porsche
Eibach is huge player in aftermarket suspension biz. A major portion of their business comes from 2.5" coilover springs. It's not worth it for them to make a couple hundred springs a year for model-specific applications.
You can still get lowering springs from B&G, H&R, Intrax, Supension Techniques, and Vogtland.
Springs aren't as important as dampers when it comes to handling.
1 - 6 of 6 Posts
