1 - 3 of 3 Posts
How easy is it to replace the front and rear sway bar bushings on a 1st Gen Avalon? Can it be done in the driveway?
I've been recommended to get polyurethane over rubber. Is there a huge difference in performance or just lifespan?
From what I've read the vehicle must be raised equally on each side. Is that correct?
· Administrator
They're pretty easy to get to. The fronts are a bit harder because access is blocked a bit.
Can't answer your question regarding rubber Vs polyurethane.
Yes, it's highly advisable to raise both sides equally. If you don't, one side will have a lot of force pushing down, so when the last bolt lets loose, it'll jump down and might injure you. It doesn't have to be raised *perfectly* even, just reasonably so; within an inch or so.
1 - 3 of 3 Posts
