1 - 4 of 4 Posts
Boosting 15 psi :)
1991 MR2 (jap turbo)
What kind of sway bar setup would promote oversteer/understeer? (stiff in back or in front) I hear good things about Suspension Techniques bars' performance, but i also heard that the bars were so stiff that they would bend the tension rod (the thing connecting the sway bar to the car itself). Is this true? If so is there any way to fix this problem, like reinforced rods?
Thanks.
91 MR2 Turbo
i have also heard that they will bend the tension rods, but now worry because twosrus.com sells some heavy duty tension rods that will take the abuse, the suspension techniques bars, if i remember right,(a friend in tulsa has them on his mr2) promote an excellent handling ride, with slight oversteer when you want it
1 - 4 of 4 Posts
