Has anyone considered swing away spare tire carrier? This one fits in the 2" receiver hitch: http://www.wilcooffroad.com/shop/hitchgate/
The AWD does not have a spare tire. It has run flats.:surprise:I'm curious - what problem are you solving by making this change? What's wrong with the spare where it is??
It'll work. I suggest opting for the Hitchgate Solo High Clearance probably.I purchased a 2017 Toyota Sienna and my first step is to have a hitch receiver installed.
I am about to pull the trigger on a Wilco Hitchgate Solo, as I plan to carry a spare on it.
A local hitch installer says they can install a Curt or Drawstite. Anybody here know if these are compatible with the Wilco Solo?
Max at Wilco says the receiver should sit flush with the bumper, but the Curt and Drawstite is recessed an inch or two.
Tom in Salem
Looks fantastic. I'd love the AWD, but I don't want run flats, I won't own run flats, again. I hope the 2021 update includes an AWD without run flats.
I was curious, likely a dumb question, with this being a 2WD, why not leave the spare tucked under the bumper?Still not all wheel drive, but we should put the 2 Wheel Dr. to the test over Thanksgiving View attachment 287583
There’s no spare under bumper, it’s under floor behind passenger seat.I was curious, likely a dumb question, with this being a 2WD, why not leave the spare tucked under the bumper?
I'm considering getting the Hitcgate Solo Hi-Clearance. Now that you've had it for a while more, are things still good? No issues? Do you feel it was worth the cost?
No issues. Still great!I'm considering getting the Hitcgate Solo Hi-Clearance. Now that you've had it for a while more, are things still good? No issues? Do you feel it was worth the cost?
Sweet! One more thing, about how much space is there between the back of the tire and the rear door? Is it hanging off the back by a lot with a gap? Thank you again!No issues. Still great!
Depends which hole you use. I’d say about 3”.Sweet! One more thing, about how much space is there between the back of the tire and the rear door? Is it hanging off the back by a lot with a gap? Thank you again!
