Well ill start with some background.
about 400 mles into ownership i noticed notchy shifting, hard shifting to 1st and slight grinding into 2nd from 1st...also the cold weather really made it worse...I drove it to 1500miles then did the switch to redline mt-90(full synthetic)
after switching, there is a big difference on cold mornings, not anywhere near as bad, the notchyness has almost gone away, but i still have the slight grind into 2nd and after reading other posts about 1sr gear, its never gonna get better(I can live with that)
all in all it helped, i put about 100 miles on it since the switch, and there seems to be no problems with the change, its no miracle cure, but its worth 30 bucks.
the change was easy, 24 mm bolts. about 2.7q mt-90, and 27lbs torque on reinstall
4 dollar handpump from auto parts store and thats it.
I just want to thank the guys that have already done it and posted advice. it was very helpful and made the job quick and painless.
