1 - 6 of 6 Posts
Feel the vibe.
01 Corolla S
i want to know if there are any known symptoms of a failing rear swaybar endlink.
i have an aftermarket swaybar - whiteline 20mm 3-way adjustable and it is on the middle setting (middle hole).
i think that may contribute to the faster wear of my endlink but i wonder if a failing endlink makes any kind of noise because I hear a noise that is hard to describe.
thanks
Big T Dizzle fo Rizzle
2001 Corolla LE
Only noise I had coming from the back related to the sway bar was a worn out stock bushing on the bar/frame interface. That was on a stock bar on a 95 Prizm. I'd imagine you have aftermarket bushings with your bar. That sound was a hollow rattling type sound.
Feel the vibe.
01 Corolla S
yeah it came with aftermarket polyurethane bushing. i hear it when i drive over potholes or bumps and it kind of sounds like a hard plastic being compressed .... that probably makes no sense lol.
2001 Corolla LE
Is that what it sounds like? :lol:
a urethane bushing will squeak if not properly greased.
If you suspect the endlinks, inspect them for cracked rubber or excessive free play in the ball joint.
1 - 6 of 6 Posts
