Hi
I installed a remote starter in my 98 Camry. I had to hook up a wire to the Tach. Now it seems that the Check Engine light comes on with a fault for a #1 Cyl misfire. The plug into the coil has 4 wires from left to right, the first wire is brown, the second is white with a red stripe. The third is solid black, and the fourth is Black with a red stripe. I have it hooked up to the third, solid black wire. I soldered this wire for a good connection. Is this the correct wire? Do others have the same problem? Should I hook it up for "Time" or "Voltage Sensing" instead of tach? Any help is appreciated.
Pat
Pat
