1 - 2 of 2 Posts
12volts white - white/red + ignition harness
Starter red + ignition harness
Second Starter
Ignition black/yellow + ignition harness
Second Ignition black/red + ignition harness
Notes: There are two black/red wires going to the same pin at the plug. use either one.
Third Ignition
Accessory blue/red + ignition harness
Second Accessory
Keysense blue/black - ignition harness
Power Lock dk. blue/white - org plug bottom of fusebox
Notes: The lock wires are about 18 gauge. They will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door itself.
Power Unlock dk. blue - org plug bottom of fusebox
Lock Motor blue/red org plug bottom of fusebox
Unlock Motor blue org plug bottom of fusebox
Parking Lights+ green bottom of fusebox
Notes: In a white connector just below the fuses with the wires exiting out toward you.
Parking Lights- green steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger red/white - top of fuse box
Notes: Located in a seven pin plug on the top right side of the fuse box.
Dome Supervision
Trunk/Hatch Pin red/yellow - light or sw. in trunk
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black or gray AC
Notes: On the 4 cylinder motor use the black wire in the gray plug at the coil on the drivers side of the motor. On the 6 cylinder motor use the gray wire located at the ignitor on a bracket just in front of the strut tower. The module says Denso on it.
Wait to start
Brake Wire green/white + bottom of fusebox
Parking Brake
Horn Trigger green/black - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/
1 - 2 of 2 Posts
