4 or 6 cylinder? Get a used gauge cluster on eBay (or wherever) that matches your motor (the redline and top speed are higher on the V6 cluster). You can swap your speedo into the cluster and put it into your car - it is plug-n-play and would look factory.
Otherwise, check the top of the distributor - on the 4-cylinder models there is a plug that a standard spade connector plugs right into.
Thanks I got my tach hooked up but that gauge cluster looks nice. What all years would fit in my 86? Does the gen2 one fit? and since my car didn't come with a tach is the car still wired for a tach that is if I just change the cluster it would work?
If your '86 is like mine, which is a DX, keep in mind that on that new LE cluster, the fuel and temp gauges are flipped in comparison to the DX cluster and it will require some fancy rewiring.
I think maybe the cables might be too short? The gen1 cluster (LE) will fit with any of the gen1 models; however, the '83~'84 are slightly different then the '85~'86. I'm not sure about the cables though since I don't know anybody who actually did do a Gen1 swap. I know I've heard people doing Gen2 DX clusters swaps with the Gen2 LE cluster without problems.
I don't know for sure if the DX and LE clusters have the same plugs for the back, but I do know that the fuel gauge wires on my DX will not reach to the other side of the cluster without being rewired or rerouted. I'm sure it's possible, but it might be a pain, just keep that in mind.
I love my '86, but I wanted a tach on mine too... damn DX!
1 - 10 of 10 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
