1 - 20 of 30 Posts
i have a 2005 tacoma that has no brake light s ive changed the bulbs and fuse still no brake light dont know if this is related but its hard to shift from park and the ac not cold
short-throw dipstick
Did you check the brake lamp switch mounted at the brake pedal?
will ck that i havenot replaced that fuse thought that was the ignition fuse never thought it would control the shifting out of park or the brake lights
It's actually the IG1 No 2 fuse that controls the shift lock. Less likely to be noticed that the IG1 fuse, controls less noticeable stuff.
The 10A Stop is for the brake lights.
The two rear tail lights ground near the rear differential, the high mount near the floor seat cross member Left Hand, so doubt you lost both grounds.
Discussion Starter #11
o5 tacoma brake lights
when you say impacted do you mean its stopped up by leaves and things like that can i use a water hose and vacuum cleaner to remove the debris the truck set for almost a year under a tree everything work until i got well enough to drive z excuse me if im asking to many questions having a hard time understanding things since my stroke thanks to all thats tried to help
1998 T100 SR5 2WD
Impacted as in the AC is affected as well. So if those fuses are blown, the AC may not work correctly. ;)
Remove debris from the condenser or evaporator? If you are careful and don't use a lot of spray force. If you do use a lot of spray force, you can easily bend the thin fins and yer AC will not be as efficient. ;)
How much debris has the tree dropped on yer truck? Snap some piccies and post them. ;)
You can never ask too many questions. Hopefully, you can git the answers yer looking fer. ;)
Discussion Starter #13
are these fuse miro or mini used all i had and t he guy at auto zone sold me the bigger size its a 40 mile drive to any store that sells fuses just want to get the right ones
Discussion Starter #14
well as hard as i tried i cant get to the ig1 fuse to replace it being disabled i cant stay bent down that long now for the 2 and part all the mechanic want anywhere from 50.00 to 105.00 to replace that fuse and if they put a end on the neg cable its another 25.00-50.00 and they have to buy the parts i mean come on a 10 amp fuses is a 10 amp fuses
and a neg cable end is a neg cable end i ask where they were going to buy them at a low and behold its the same store i was using what a crock
Fuse IG1No 2 is bottom row center of the fuse box above your left knee when driving.
Kneeling next to truck is easiest, but with your concerns I can see problems executing.
The fuses are called ATM low profile according to sources other than me. Might be called low profile mini fuses.
Discussion Starter #17
well got the fuses replaced and still no brake light was told only thing left is the stop light switch have order one will get it replaced as soon as it comes in
1998 T100 SR5 2WD
Discussion Starter #19
that would be a great ideal if i was able to test the switch being disabled i have to have some else do it and most people will help me replace the but dont have the time to try and trouble shoot the switch we tested the switch and found that it would work some of the time but not all of the time when it worked tail lights worked ad we could shift the truck out of park
1 - 20 of 30 Posts
