1 - 3 of 3 Posts
Well if I let my car sit overnight, when I start it in the morning, i turn the key and I have to keep it turned for about 3-5 seconds, the starter is turning it just takes a few seconds to turn over and start, and when i does it sputters for a second. Then after that it idles and drives perfect. What could be causing this?
Cressida nut
91 Pickup (Hilux)2wd
to restate my TC.net response:
very likely:
-faulty fuel pressure regulator (leaks down when fuel pump's off)
-faulty check valve in fuel pump
-slightly loose fuel fitting (enough to bleed pressure overnight, not enough to be noticeable) (this is how mine is)
very likely:
Alright thanks, I'll check for leaks. How can the check valve on the fuel pump?
1 - 3 of 3 Posts
