I am adding a secondary battery and placing a relay under the hood, but I need to tap into ignition turn on line, can someone tell where I can do this.
look around the fuse box and check to see what goes on when the key is turned to "on" and off when it's "off". use a test light and check any wire that is back w/ yellow stripe.
