1 - 2 of 2 Posts
I don't exactly know how to call this part of the car, but the black plastic surrounding the window switches on the drivers side vibrates when playing music, making it really annoying to listen to music. If I put my hand on it, I don't hear this sound anymore. That part seems to be loose, causing it to shake when there is bass.
Have any of you experienced this? Is there a way to fix it?
Thanks
You could do a couple things...
There's a simple clip holding down the back of the switch bezel into the panel and the front just slides under the opening in the door panel....
Add some felt tape to the clip to make it a little tighter..
Add some felt tape to the bottom edge of the bezel where it contacts the door panel to eliminate any looseness that may be there.
One of those two options should take care of the problem unless the switch bezel is broken.
1 - 2 of 2 Posts
