I've installed the latest version of Techstream (7.10,030), and it does appear to be communicating fully with the car (2012 Camry SE). everything seams to work (can see the ecu's and error codes) except I cannot access any of the options to change them. I can see the options screen, but when I select one, it appears to be trying to access the vehicle but nothing comes up. I've started with windows 7, but then removed it and tried running it in windows xp running it in windows virtual machine with the same results. Has anyone had the same problem and how did you fix it?
