Hey, I'm new here. Although I have been browsing this forum for a few months. I've done a few searches for this but couldn't find any info.
Basically I have a 91 Camry A/t, and my temp gauge goes straight to hot when I switch on the ignition, and doesn't budge from there. I have replaced the gauge with a good one but no fix. If I plug out the sensor that goes into the t-stat and turn on the ignition, the rad fan comes on, so I'm thinking the sensor is working.
No problems at all with the cooling system, after about 10-15 minutes of operation, the fan comes on, does it's job and then turns off. I just need a working gauge, so if something goes wrong, I will know.
IMO it has to be an electrical problem, either the wiring or the relay, if there is one? One thing that might point to it being the relay relates to when the gauge stopped working. As most Camry owners know, these cars run very quite @ idle and what I think might have happened is, when my mechanic was working on the car he left the car running for a couple of hours, not realisisng it was on and blew the relay for the temp gauge.
What I need to know is where the relay is for the temp gauge or what symbol would denote a relay on a wiring diagram?
Thanks
Z
Thanks
Z
