Ok at first I was 100% sure that my thermostat was stuck to wide open because it seamed that if I was stopped at a light my temp would eventually go up to normal and if I was driving it would drop down to half way between normal and cold (this was happening for the past 2 days and it has been hot around here). Just now I was driving, stopped at a light and the gauge started fluctuating up and down about 2 times rather quickly between normal and half way to cold... and then it just went back to normal for the rest of the trip…
So do you think the problem is the thermostat the sits on the water pump or the sensor down near the bottom of the radiator? Cuz now I think it is the sensor.
If it is the sensor down there then I guess I will have to take it into a shop cuz it looks like it is a bitch to get to
Anyone done this or know how much it will cost? thanx (I will be replacing the thermostat regardless becasue it has never been done)
Thanx
Thanx
