On Mon, 01 Jan 2007 13:13:43 +1000, cyb wrote:
> i have a 93 V6 camry. the temperature doesn't work at all. anybody has
> ideia?
Are you getting heat inside the car? If not, the thermostat may be stuck
open and the engine is not heating up.
If heat's not a problem, look around the thermostat housing. That's where
the sending unit is. Make sure everything is connected properly. If there
aren't any loose connections, you probably need a new sending unit. Also,
when you find the connection, chack to see if it's corroded. If it is,
'wipe' it with Emery cloth, and get some dielectric grease that is used on
spark plugs; any parts store will have it. Put some grease on the contact
and slide the connector back on and see if this solves the problem.
Good Luck!
