if the radiator was pluggedit would overheat all the time, you need the radiator at all times all speeds regardless
same with the waterpump if its going out then it iwll overheat all the time
when its hot make sure the system is under pressure, if you squeeze a hose when its hot it should be underpressue you should not be able to squeeze it in
if you can then you either have a junk rad cap, or an internal or external leak
the rad should be evenly the same tempa ll over it
if it has hot or cold spots or one side is hot and the other alot cooler then something is very wrong
the fan should be able to suck enough air through the rad to be able to feel it out in front of the radiator, it should feel like cold air binig sucked into the front of the radiator
if not then something is wrong
broken shroud, bad fan clutch
etc
when the truck overheats will tell you/us alot
unless its doing it at all speeds all the time
good luck
