1 - 3 of 3 Posts
Hey guys , I just put a 130amp alternator in my truck and my factory tension arm maxed out won’t go far enough to get tension on the belt , has anyone had this issue , have you just used a shorter belt ? Custom tension arm .
I used a 46” belt instead of the 47” it was running fine , I just started my truck , my park brake light is on the charge battery and I’m not getting a proper charge on my battery , does any one know what fuse or relay is for the dash instruments ? I checked all the fuses just not sure what one is for the dash
1 - 3 of 3 Posts
