93Tercel said:
I would like to know is if you can just swap a head off a Paseo and put it onto a Tercel block?
Why? They are the same thing. That is, the 5E-FE (non-DIS) in the Tercel and the Paseo 5E-FE heads are the same. Well, almost the same. Not exactly. There are a few differences, and I forget what ones they are. You aren't going to be able to swap a 5E-FE head onto a 3E-E.
What you might to think about is swapping the entire engine out. I assume you have the 3E-E. Not worth it man. Once they get past 100k miles, they tend to start burning oil pretty bad.
Look into swapping the cynos 5E-FHE or a paseo 5E-FE or a Starlet GT 4E-FTE in.
And by the way, the search feature is priceless.
