even better! :thumbup:Unless you have to have it on the outside, I still think the "stealth" installation that my local shop did in my old XLE was by far the best way to go.
The antenna is "supposed to be on metal." So, what's underneath the plastic "parcel shelf" in the back window? A great, big metal shelf. And that plastic won't block any signal whatsoever. So, just get underneath the plastic parcel shelf, and put it on the metal shelf underneath it. Nobody will ever know that you've got a satellite radio in your car. Perfect!
Otherwise, I suppose it ought to be just like the OEM installation -- as far towards the back of the car as you can possibly get it, to get clearance away from the roof.
Do you (or anyone else) happen to have photos of the installation location on the interior of a gen6? I'd love to get it off the outside of my car - but I'm not quite picturing the location (and my car is at home).Unless you have to have it on the outside, I still think the "stealth" installation that my local shop did in my old XLE was by far the best way to go.
I just don't know -- I've never actually "seen" it. It's "magnetic," right? As in "designed to be attached to the roof of the car?" If so, I expect it's just sitting on the metal shelf under the plastic shelf, hanging on because it's magnetic.Thoots- was the "stealth" antenna fastened to the metal shelf under the parcel tray, or was it just sitting there, ie:, trapped between the plastic and metal? Taped? Screwed? pressed into plastique....?
