Reflects a lot of heat. Anyone using a light colored dash cover?
This is true that over time you will adjust to the reflection and not be aware of it. But, the reflection is still there and reducing visibility so it's best to eliminate it or reduce it as much as possible. Here's an example of what I'm saying with sample photos in another forum - http://www.cadillacforums.com/forum...-reflection-dash-windshield.html#post15957201...So if the dash is all gray, your eye adjusts and its not distracting...vs a notepad on a black dash.
Dark dashes absorb heat not reflect it. Light colors reflect heat but are also more subject to UV penetration wear n tear. This is why most manufacturers use a dark dash or a two tone and the darker is the top.Reflects a lot of heat. Anyone using a light colored dash cover?
The dark dash does absorb heat and then reflects/radiates heat toward the driver and passenger. We can feel it in spite of the AC.Dark dashes absorb heat not reflect it. Light colors reflect heat but are also more subject to UV penetration wear n tear. This is why most manufacturers use a dark dash or a two tone and the darker is the top.
