1 - 5 of 5 Posts
Hello,
I Just bought a Toyota Corolla 98 for a cheap price. I really do not know if it is reliable or not. A mechanics looked at it and told me its OK, another one said not very good condition. The seller insisted that the car is very reliable.
I drove it today for about 60 miles. It was running good. When I came home in the parking I turned it off. But, when I wanted to start again it cranked but did not start. I try 3 times, and the engine starts firing. The gas gage was showing near empty. After filling it out again, it starts fine again. I do not know about this car very much and the previous owner also did not give me enough information about it. What can be the problem? The seller told me he changed the battery last winter. But, it seems the battery really older than 6 months.
I have zero experience fixing a car. I have no clue what part I should check for this problem. Could please give me a clue? can it be battery, alternator or something else
Thanks
My initial thinking is the battery and not necessarily that the battery is not good anymore, but one (or both) terminals are dirty/damaged. Are you check the terminals already? You can start with the positive terminal, that generally gets dirty, but check both and check if any is loose. I had a similar thing couple of months ago and was that the positive terminal was dirty/loose.
2002 corolla ce
I think I read this right but going to recap what's going on to ensure I read it right
1) drove 60 miles with 20% gas tank remaining
2) left car for a bit but returned with engine still warm.
3) tried to start it but engine wouldn't crank
4) tried again clicking noise happens but no crank
5) tried a 3rd time car starts and runs fine
If that's what happened I'm pretty sure your starter is toast. More specifically your contact solonoids are worn. Fairly easy fix and try RockAuto.com if you want cheap quality parts. Denso is oem btw
1 - 5 of 5 Posts
