1 - 20 of 52 Posts
· Semper Paratus
Toyota Tacoma 4.0 Exhaust FAQ
It seems that new people to Toyota Nation are having a hard time finding good information. Well I have compiled a little “cheat sheet” for those who are considering a new exhaust. I put down what I know in hopes that it will help someone out. Remember, even though I put the best information I could find, prices change and I might have missed some things. If you find something I left out let me know.
Now then, let’s just dive on in. Your aftermarket exhaust systems are separated into three major sections; Headers/ manifold, Y-pipe, and cat back exhaust.
Headers
The first section, headers/manifolds, brings the exhaust gas from the engine to the main exhaust pipe. The stock system is called a manifold. You can upgrade your system here by converting to headers. The two main companies that make headers for the Tacoma are Doug Thorley and JBA.
Doug Thorley (DT) headers; Doug Thorley makes long tube and shorty headers. Long tubes give you more horse power but are not smog legal. You also have to buy O2 simulators to replace the stock sensors. If you don’t your check engine light will stay on. Shorty headers give an increase in power and are smog legal. The long tubes are completely bolt on. The short tubes require some welding. You can get these from Coast2Coast performance
Doug Thorley's website with video
Link to view install of long tubes (thanks to TRD sport from XR underground)
Coast2Coast's website
JBA Headers; JBA produces shorty headers made of 409 stainless steel. They are available in three different finishes depending on your application. You have to have these welded to your stock system about $350
JBA's headers link
Don't buy JBA Headers link
Summary; if you want power go with DT long tubes all the way. If you want a decent power gain while staying smog legal, DT short tubes are a smart buy.
Y-pipe
The only company that I know of that makes an upgrade to the stock Y-pipe is URD. It is a 3” stainless steel pipe that removes the catalytic converter. About $470
After Cat Exhaust
Usually the first upgrade people do to their exhaust system is an after cat exhaust system. There are many exhaust systems out there. More than I know, so I can only list the ones I do.
TRD; single exit, good tone. This system may not give you as much of a horsepower gain because this system maintains the stock exhuast diameter. Most other aftermarket systems increase the diameter of the piping to increase flow. More flow= more power. I'll post actual HP numbers when I find them. The cost for this system is around $340-$375
Banks; 3” Stainless steel single exit exhaust. Good deep tone. The cost for this system is from $410 to around $470. If you get this exhuast you should know that the hangers are mild steel and will rust. You can paint the hangers with hi temp engine paint to minimize this. A more expensive option is having your exhuast ceramic coated
Magnaflow; 3’ stainless steel single exit exhaust comes in @ around $450-$475 depending on application
Magnaflow review by Flat Spot
MBRP; Dual split side exit exhaust made ofT304 stainless steel. If you want dual exhaust this is the way to go. The cons are that the increase in power falls shorter than most 3” single exit exhausts and it is the most expensive of the group @ around $690. Haven't seen this exhaust in person but I heard that it sounds really good.
MBRP's Website with video
Flowmaster; Dual exit 2.5" pipes with dual mufflers and 3" stainless steel tips. $565
Flowmaster Tacoma exhuast website
Gibson; Stainless steel single exit exhaust around $450-$480
Jardine; URD’s main product line. They sell for around $270
JBA; there have been posts that say this system tends to rust.
JBA exhaust link
Borla;
Dynomax;
The Dynomax website
Dynomax ultraflow exhuast video (thanks to ShoeDR)
Summary; When I bought an after cat system for my truck I went with Banks. This doesn’t mean it’s the exhaust you should buy; it’s just the one I chose. I have known alt least one owner with each of the systems above and each owner liked the one he purchased. It really just comes down to preference.
Mufflers/Custom Bent Tubing
Many people have swapped out just the muffler or had a shop custom bend pipes for their trucks. If you've been looking at the pre-fabricated systems and they just don't give you what you want (such as tip placement, tip type, etc) then this is the route you should take. this route is also usually a little cheaper.
the most popular mufflers are Flowmaster and Magnaflow.
flowmaster 80 series muffler
If any one has clips they would like to share of one of these systems I will add them here.
spin tech #3332 sportsman street 2.5" center inlet to side outlet;
spin tech
spin tech 2
spin tech 3
O2 SENSORS SIMULATORS (O2 SIMS)
If you put long tube headers on your truck you need O2 sims. Your new headers are going to remove the first set of catalytic converters (pre cats.) This will change your O2 output and set off your check engine light.
Two companies make O2 sims;
URD; If you buy these along with the long tubes from URD you can get them for $29. The only downside is that you have to cut and splice some wires.
URD's website
Empire Performance and Offroad; more expensive but completely bolt on. Most people order #1303 but you can get #1304 about $140 to $170
Empire's website
The end. :)
I'm still working on this. I'll try to get more links and more information when I get time. If anyone wants to give info or opinions I'll appreciate it.
Help: If you have an aftermarket exhuast, help out new members by posting the following;
type of exhuast, cost, place purchased, and a rating from 1-10 (10 being the best). I'll put all of your info into the FAQ and make it even better.
If you have had a bad experience with an exhuast post that as well. It may keep someone from making the same mistake.:thanks:
Thanks jubrown57;this is why I love TN !So many knowlegable people sharing useful info..The down side is my bank account is being hammered.
Reactions: eeklipzz
06 Taco D.C. Sport
i thought there were people that dynoed their truck with a TRD exhaust and possibly a TRD intake and gained some power?
i havent been here for a while so i cant remember much.
is there anyone that can clarify that statement about the TRD not giving the truck a gain in power.
· Semper Paratus
Discussion Starter · #9 ·
I think that the TRD might give you an increase, just not as much as other aftermarket exhuast systems. Mostly becuase of pipe size. I've heard the TRD has the same size piping as the stock exhuast. Most aftermarket systems go up to a bigger size pipe.
Nice job jubrown. Should we add a section for cold air intakes and URD MAF calibrator to complete the performance upgrades?
Also for the exhaust section, there needs to be some words on Flowmaster and Magnaflow mufflers (not just complete catback).
· Softball God
07 Tacoma V6 SR5 DC
TRD; single exit, good tone. There are rumors that it doesn’t increase power.
Conjecture and "rumors" shouldn't be part of a FAQ. As mentioned above, mention should be made of Flowmaster and Magnaflow mufflers since many of us who have gone this route.
· Stupid is stupid does
2008 tundra
true, Maybe the OP can change this and update it as needed. :thumbup:
· Semper Paratus
Discussion Starter · #13 ·
I understand that "rumors" should not be a part of a FAQ. Do you know where I can find the gains of all these systems? Without it I don't want to say for a fact TRD makes less. I made this to help people get all the information they could in one place. I have not yet researched TRD exhaust systems but I did see this written severel times in other posts. Since this info is out there, I tried to put it in here. the other posts mentioned that because TRD did not increase its piping size it did not flow as well as other aftermarket exhaust systems. less flow= less power. So as soon as I get the chance I will find out and rewrite that section. If it bothers you help me fix this by finding dyno sheets for these systems.:D
2008 tundra
Just a thought. Not everything in the DIY and FAQ is all true word for word. :thumbup:
how's about the info for the stock exhaust? it seems that a lot of people just want to swap out the muffler. there's been a lot of conflicting info regarding the correct diameter of the stock piping and proper aftermarket diameter and inlet/outlet configurations.
from what i've read, an aftermarket diameter of 2.5" (with stock being around 2.3") with a center inlet, offset outlet would work best. correct me if i'm wrong, especially since thats what i'm planning on going with!
1 - 20 of 52 Posts
