1 - 20 of 213 Posts
i love emmanuelle chriqui
alright so i am making this thread to avoid more question on lexus rims on either gen 5 and 6.
Centercaps: (size is 2 5/8's inches)
http://www.centercaps.net/caps/listing.php?make=22 (courtesy of El Loco VG)
http://www.centercaps.net/caps/details.php?stockNumber=501 ($18.99)
TIRE SETUP:
GEN 5
CE/LE/XLE and SE 4CYL = 215/60/16 TIRE DIAMETER: 26.1
SE V6 = 215/55/17 TIRE DIAMETER 26.3
GEN6
CE/LE/XLE = 215/60/16 TIRE DIAMETER:26.1
SE =215/55/17 TIRE DIAMETER: 26.3
here are the options.
LEXUS ES 330 WHEELS
1.
17x7 +50 offset
RECOMMENDED tire setup: 215/55/17 (same setup as SE wheels) or 225/50/17
heres on on a es300 *same look as gen4 camry.
setup is on 225/50/17..
LEXUS ES 350 WHEELS (GEN 3 ES 06+)
1.
gen 6 camry
2.
17x7 +45 offset
RECOMMENDED tire setup: 215/55/17 (DIAMETER=26.3)(same setup as SE wheels)
or 225/50/17 (DIAMETER 25.9)
LEXUS GS WHEELS
GEN 2 GS WHEELS (98-05)
1.
5 spoke 17x8 +50 offset
pic on a gen6 camry
Here's my car if you want a sample of the rims on the camry[/QUOTE]
2.
these are rare gs400 wheels
7 spoke 17x8 +50 offset
RECOMMENDED TIRE SETUP IS 235/50/17 (DIAMETER 26.3)
GEN 3 GS WHEELS 06 +
1.
17x7.5 +45 offset
pic of them on my car 225/50/17 setup (DIAMETER=25.9)
2.
18x8 +45 offset
pictures on lammy's car.
on SE member name chitty
3.
18x8 +45 offset
recommended tire setup is 235/45/18 (DIAMETER 26.3) OR 225/45/18 (DIAMETER 25.9)
LEXUS IS WHEELS
IS300 WHEELS (99-05)
1.
gen 5
2.
17X7 +50
recommended tire setup 215/55/17 (DIAMETER 26.3) or 225/50/17 (DIAMETER 25.9)
IS250/350 WHEELS (06+)
1.
17X8 +45 OFFSET
recommended tire setup 235/50/17
2.
18x8 +45 FRONT 18X8.5 +50 REAR.
recommended tire setup 235/45/18 (DIAMETER 26.3) front and rear
OR 255/40/18 rear (DIAMETER 26) (stock tire setup from rear wheels IS)
pics on darksparks camry.
on a gen5 camry from techtable
3.
18x8 F 18X8.5 R
recommended tire setup 235/45/18 front and rear OR 255/40/18 rear (stock tire setup from rear wheels IS)
LEXUS RX WHEELS. RX330-350
1.
picture on gen 5 camry ASIANRICK.
2.
18X7 +35 OFFSET.
OPTIONAL WHEELS..
LEXUS G-SPIDER WHEELS
18X8 +45 F 18X8.5 +50 R
on my car.
18x8 +45 all around 235/45/18 tires
there are 2 more wheels that are options for 2010... i will have to research some more..
please post pics of your camry on LEXUS wheels!
Loving the camry =)
good job organizing, didn't realize camry drivers love lexus rims that much.
thanks for the input. I think its because camry owners want style without sacrificing comfort. 17 and 18's are pretty much comfortable.
Discussion Starter #6
No problem bud...
Added some more examples on the first post.
Hey does this car belong to a member here? I've always liked these wheels in the dark graphite color. They can be had really cheap but does anybody know where to get these Toyota center caps? I've looked and haven't found any real info. Best I found was that the Toyota Avensis center caps fit but where does one find those? I put Acura CL wheels on my accord back in the day and I was able to buy just the H logo (official Honda part from dealer) which I drilled into the Acura center cap and it had adhesive on the back and had little locking like washers that compressed onto the pegs behind the center cap anybody knows if Toyota makes these?
Apparently this is what was talked about but from what I found this is a 16" Sasceo aftermarket alloy wheel for Toyota Avensis II So again I've hit a dead end.
2GR FTW
Note:
For the IS250/350 18" wheels, since the rear are at +50, you need a very small spacer for it to clear the strut, I used a 3mm and it's fine.
Discussion Starter #10
Note:
thanks man. I wasn't sure if it will fit with no problems without the 3mm spacers.
Discussion Starter #11
Toyota Centercaps are really hard to find.. the size is 2 5/8's inches. i found mine on ebay. fitment of the OEM Camry and Avalon wheels fit. as well as the gen 8 and 9 Corolla.
hope this helps.
What is the compromise with using the Enkei EKM3 vs. the G-spider wheels. I know that I will need a hub centric ring. What else… weight? I have a white 09 CE. You think a silver or gunmetal will look nicer.
Discussion Starter #14 (Edited)
both are made by enkei... one is model specific oem and the other is aftermarket. the good thing about the enkei's is they have 18x8 +40 which pushes the rims to the fender a tad better. weight the enkei's might be lighter. Price? Better deal with lexus. IMO.
Hey Jan, good job putting this helpful thread together. :clap:
Thanks Sir! :thumbsup:
Discussion Starter #17
If they can be had cheap I'd like to know where. That's what I'm looking for, but I'm settling for the LExus IS250 wheels. 'cause I'm cheap. Hah.
ebay,clublexus and craigslist. theres a guy selling IS250/350 wheels for 350 now @ club lexus.
for take-offs, i would pay 300-600 a set. for new wheels like the ones i had, i payed 950 for wheels. 700 for tires.
I've been looking at that ad. I was actually referring specifically to that model wheel - I like the simple pattern.
I'm probably gonna pick up some from a local craigslist guy if I can talk him down a bit.
My car has the "low tire pressure" idiot light.
I have no idea how this system works. Is this something I need to worry about when installing new wheels/tires? I notice when I did some comparison pricing on the Firestone Auto Care website (wow, waste of time) that it had a checkbox for this type of thing.
Here and there...
There is a sensor in each of your wheel/tire that send a signal to a receiver inside your car. So when you tire has low pressure the light will come up.
So check the pressure on all your tires to make sure they within specs of 30 psi. Toyota recommends 30 psi for our Camry but most of us go between 32 and 35 psi. If the light keep coming back within a few days that mean you have a slow leak that need to be fix.
When you install a new wheels, you will need to transfer these sensors to your new wheels for obvious reason.
1 - 20 of 213 Posts
About this Discussion
77 Participants
2007TCHybrid
Toyota Nation Forum
Full Forum Listing
