1 - 14 of 14 Posts
XRS
Discussion Starter #1 (Edited by Moderator)
This is going to be a work in progress so please add your suggestions and I'll be happy to include it in this list.
General Information:
OEM wheel info:
Brake torque specs:
1ZZ-FE exhaust:
2ZZ-GE exhaust:
Lift locations:
Stock speaker specifications:
Spark Plug info:
Iridium-tipped spark plugs are used. 120000mile (192000km) maintenance interval.
Denso SK20R11
NGK IFR6A11
Plug gap: 1.0-1.3mm (0.0394-0.0512")
Transmission codes:
2ZZ 6 speed = C60
2ZZ auto = U240E
1ZZ 5 speed = C59
1ZZ automatic = A246E
1ZZ 4WD = U341F
How to adjust fog lights:
How to adjust headlights:
AFTERMARKET PARTS
INTAKE:
TRD
- drop-in filter
- cold air intake
AEM
- short ram
- cold air intake
Injen
- cold air intake
K&N
- Typhoon Kit (short ram)
Cosmo
Weapon R
EXHAUST:
TRD
Borla
Greddy
Vibrant
Tanabe
Magnaflow (cat-back)
HEADER/EXHAUST MANIFOLD:
TRD
Trial
Hotshot
DC Sports
UNDERDRIVE PULLEYS:
Unorthodox
AEM
SUSPENSION
SPRINGS and Spring Rates
Tein H-Tech - Front: 129lbs, Rear: 151lbs
Tein S-Tech - Front: 154lbs, Rear: 190lbs
Tein SS Dampers - Front: 280lbs (5k), Rear: 280lbs (5k)
Hotchkis Street Coil Spring Set - Front: 180lbs, Rear: 350lbs
JIC JIC FLT-A2 - Front: 335lbs (6k), Rear: 448lbs (8k)
TRD Coilovers - Front: 250lbs, Rear: 250lbs
TRD Spring Set - Front: Progressive, Rear: 205lbs
Eibach Prokit - Front: ---lbs, Rear: ---lbs
Eibach Sportline - Front: ---lbs, Rear: ---lbs
Progress Spring Set - Front: 180lbs, Rear: 230lbs
Skunk2 Coilover Sleeves - Front: ---lbs, Rear: ---lbs
GroundControl Coilover Sleeves - Front: ---lbs, Rear: ---lbs
Tanabe NF210 Springs - Front: 140lbs (2.5k), Rear: 162lbs (2.9k)
H&R Sport Springs - Front: ---lbs, Rear: ---lbs
Dropzone Springs - Front: ---lbs, Rear: ---lbs
Dropzone Coilover Sleeves - Front: ---lbs, Rear: ---lbs
Intrax Springs - Front: ---lbs, Rear: ---lbs
Suspension Techniques Springs - Front: ---lbs, Rear: ---lbs
Vogtland
STRUT/SWAY BARS
TRD
Hotchkis
Progress (rear sway bar only)
LIGHTING
TYC
DECALS/OVERLAYS
importequipment.com
CF HOODS
Fiber Images
Vented CF hood
OTHER
TWM Short Shifter
Speed Source shifter cable bushing and shifter base bushings
03' Matrix XRS 6sp
Energy Suspension Motor Mounts (inserts)?
So I did the DRL mod this weekend... but I had a question. I have an '05 XRS (6-speed) So I spliced the red/white wire coming from inlet #12, the half of the wire that is coming from the DRL module itself, I ran a wire to the toggle switch and connected that half to the relay marked load, the other half of the red/white wire coming from the below the steering column, I ran a wire to relay on the switch marked source, and I grounded the toggle switch to a screw under the module itself. Is that the right way to connect??? I ask because, I turn the toggle switch to OFF and when I am parked the lights do not come on. but when I take the Prking brake off the DRLs seem to come on. In other words I am not able to actually have "no headlights" ie the headlight to not stay off. The auto sensor that turns on all of the lights still works just fine. but even when there is enough light to turn those off the headlights are still on as if I had teh DRLs still connected. also, if I trun the switch to "ON" even if the car is turned off the lights just stay on.... REALLY confused as to what I did...??? I believe that I did the connection correctly... someone please help! I understood this mod to completely take away DRLs??? anyone have a suggestion???? thanks in advance...
wheel/rim compatibility
Anybody know what wheels/rims fit a Matrix/Vibe. I'm just looking for some cheap winter rims to mount snow tires. Honda Civic ones look the same but on measuring the holes they are different. Any ideas??
Hey guyb,
Not sure if Civic rims are the same bolt pattern, however you will want to find...16"x6.5" 5 bolt on 100mm diameter circle. The rim offset is 39mm.
You can compare this to the civic wheel specs.
I would like to purchase a smaller 15" steel rim for my '05 Matrix and I am just wondering if anyone has done this and what size works?
Dealer did not have any clue size 15" is not a stock size.
Steevo.ca
1 - 14 of 14 Posts
