dittohow much
dittohow much
Hey man, no problem at all. I know when dealing with wheels and tires it can seem a bit overwhelming with all the options, sizes, measurements, different patterns, and so on. It took me a little bit to understand all of the rules and such but once you understand it, its pretty straight forward. Also thanks to the internet there are a ton of sources out there for you to do research and help you along the way.KnightRyderx2
I appreciate all the information you provided. I thought about responding to all the information you provided previously but I didn't want to spam the wheel section. All in all, thank you so much for all the tips. You helped guide me in the right direction and I ended up making a decision on going with Motegi's for the wheels. They just came in today and are now all installed. America's Tires were more than willing to spray my calipers as well. Here's couple photos.
Stock p225/45r18 on the tires, on wheel 18x8 and I asked when I went in for a re-torque on the offset and he said there isn't one.The wheels look good. Its a good contrast with the red stripe and all. What are the specs on those wheels and tires; inch diameter x inch width x offset mm and tire size? Also, can you take a side shots to show how flush they are? This is so future people can see what that size wheel and tire will look like.
Well the guy that was re-torquing it. I told him I was inquired to ask for an offset and he tried to describe to me what an offset was (which still isn't all too clear to me) and I ended up asking him, "So to my understanding of just learning this stuff as you described it seems there isn't an offset, so does that make it a zero?" and his response was "yes". The guy never originally worked on my wheels or anything, don't even think he was there the day before or anything. Friendly guy but talking wasn't his strong suit.^He said there isnt an offset?!![]()
Thanks for the pics man. He really said there was no offset? All wheels have offset, its a standard wheel measurement. If there was no offset you would not be able to estimate how the wheel will fit. You would not know how it will sit in terms of strut and fender engagement. I'm not attacking you or anything just surprised that a wheel guy said there is no offset.Stock p225/45r18 on the tires, on wheel 18x8 and I asked when I went in for a re-torque on the offset and he said there isn't one.
Gotcha :thumbsup:Well the guy that was re-torquing it. I told him I was inquired to ask for an offset and he tried to describe to me what an offset was (which still isn't all too clear to me) and I ended up asking him, "So to my understanding of just learning this stuff as you described it seems there isn't an offset, so does that make it a zero?" and his response was "yes". The guy never originally worked on my wheels or anything, don't even think he was there the day before or anything. Friendly guy but talking wasn't his strong suit.
I will take a look next time I take it off. I don't see much difference in location compared to where my stock wheels were though. That was a concern of mine. I am constantly going up logging roads / gravel roads so I don't want too wide. Thanks for the information though, it's slowly making sense and at least I have an idea on where to lookThanks for the pics man. He really said there was no offset? All wheels have offset, its a standard wheel measurement. If there was no offset you would not be able to estimate how the wheel will fit. You would not know how it will sit in terms of strut and fender engagement. I'm not attacking you or anything just surprised that a wheel guy said there is no offset.
I will take a stab in the dark here and say they are +40 or +45, about stock fitment. I say that because they sit at about stock fitment. Next time you have the wheel off check the inside where the hub sits, its usually stamped in there.
I will check that out in between my classes tomorrow. I'm rather interested now, especially after the guy there described it in person.TireRack.com has a good tut on it.
Will thing is that I don't know too much about this stuff. I just started learning it so I don't know a whole lot. I spoke with someone at tirerack and the guy recommends a 245/40 tire but that a 235/40 will work as will. But if I go with a 245/40 tire I don't know if it makes a difference if its 19x8 or 19x8.5. Also the offset is 40 on the wheels but I'm still a bit confused on that part. Flush with the fender would be nice but again, I don't know a lot of this stuff.235/45 would be good for the 8.5. In my opinion too big for the 8. For the 8 I would go 215/40. Tons of pictures on the internet on how different size tires will sit on certain size wheels. Kind of depends on what your going for and the look you want. You said you have coilovers, so I assume your going kind of low? Little bit of tire tuck? Are you going with an aggressive offset, flush with the fender, maybe sticking out just a tad? Ok with running a little more then stock camber? Any reason not going with a wider wheel since you do have coilovers?
The OEM offset is 45mm so an offset of 40 would take it 5mm away from the suspension (45mm - 40mm = 5mm), and towards the fender...not an issue...but tire size and any changes to the suspension may affect the fitment...Will thing is that I don't know too much about this stuff. I just started learning it so I don't know a whole lot. I spoke with someone at tirerack and the guy recommends a 245/40 tire but that a 235/40 will work as will. But if I go with a 245/40 tire I don't know if it makes a difference if its 19x8 or 19x8.5. Also the offset is 40 on the wheels but I'm still a bit confused on that part. Flush with the fender would be nice but again, I don't know a lot of this stuff.
