As far as the wheel width and tire combo your good. You will end up going 14mm toward the strut and 19mm toward the fender. I would add a 5mm spacer in the rear for a more flush look. If you want a super flush look go with a +30 with a 5 mm spacer in the rear. I'm not sure how flush you should go with that size of wheel. There leaves very little travel between the tire and fender. I highly doubt you will run into any wheel rub with those combinations but if you do a simple roll should be good.
