does it happen throughout all gears? or just first? any wierd noises or smells? is the exhaust smokey/white/blue?
jon
jon
yea, i can...userlain said:can you drop the clutch from 3000 rpm in first and squeal tires?
well it's not during shifting because it's on first gear. When the car is about to start moving from 1st gear, the whole engine shakes like mad crazy. But 2nd, 3rd, 4th, and 5th gears are perfectly fine.Gridlyne said:Have you tried giving it a little more gas while your shifting?
yea, the car definitely shakes on reverse also. How many mounts do i have in my car? again my car is a 2000 camry with 5sfe and manual tranny.chronoti said:well you can look at your mounts it probaly the front and side mount. if you feel it in reverse then also you back mount. also check your tranny mount. if you need anymore info with mounts search the site.
4 mounts.tightcamry129 said:yea, the car definitely shakes on reverse also. How many mounts do i have in my car? again my car is a 2000 camry with 5sfe and manual tranny.
how can i check and see what kind of shape the mounts are? it's just rubber right? so if it's all cracked and split, i know i should change 'em?88 LE said:4 mounts.
Front engine mount, rear engine mount, dogbone mount (on the left side of the motor), and tranny mount (on the bottom of the tranny).
The dogbone mount is easy to check. You'll know if its cracked just by looking at it.tightcamry129 said:how can i check and see what kind of shape the mounts are? it's just rubber right?
Yup.so if it's all cracked and split, i know i should change 'em?
Front engine mount, rear engine mount, and dogbone mount. But while your at it, you might as well check the tranny mount too.so particularly to my problem, which mounts should i pay closer attention to?
no the clutch was replace about 5000 miles ago. Pretty much brand new.dj14901 said:Is your clutch slipping badly?
DJ
Has it done this only since the clutch was replaced?tightcamry129 said:no the clutch was replace about 5000 miles ago. Pretty much brand new.
I have a tough time driving mine 1st thing in the morning, the lack of off-idle power and the fact that it fast idles at 2K RPM makes it difficult to drive...pgmomni said:just in 1st when starting car from a stand still.
i have no idea when my clutch was changed last.
felt like a contaminated clutch disk to me,
like my rear crankshaft oil seal is leaking oil into the clutch
housing.
but i just hit the gas and pop the clutch and it stops!
pete
