1 - 20 of 50 Posts
I'd love to see a write-up when you're done, including both your opinion of the device, as well as photos showing the install (detailed pics showing how to install it, as well as the final product).
I settled
for now; I know it won't be perfect, but I hope it's good enough!
· Premium Member
08' Tacoma Dbl Cab
You should be able to use the cable that came with the ipod to sync it to your PC (or MAC if that is your fancy). The GROM unit uses a USB port just like your PC.
EDIT: It does however look like they have a proprietary cable that can be used to connect the ipod if you wish. If you don't want to spend the extra $20 you should be able to connect it through the USB port, but it may affect your ability to control the device from the stereo and charge it from the adapter.
That's what it looks like. I'll be interested to see how this set-up works for him; looks like it may be pretty sweet! :thumbsup:
· Premium Member
08' Tacoma Dbl Cab
Yes, it does! But, if I were looking for an OEM integration solution (I am not because I yanked my factory stereo less than a month after purchasing my truck), the only thing that would bother me about this adapter is that is doesn't display track names and artists from the Ipod (or USB source), but it beats the heck out of an FM transmitter!!!!!!
Keep us posted Dark_Taco! I am interested to read your review after install!
Got one of these from costco......not great at all.
I can't stand those things. They do the job in a pinch, but they do it pretty horribly. I'm really hoping that the modulator gets better sound (it's wired to the stereo via the antenna). It was $26, so if it sucks, oh well.
If yours turns out well, that may be my next move. Either that, or a new head unit.
· Premium Member
When using my Grom interface from the IPOD, it will only display track info on the newer IPODs. And then I have to do something like select disk 2 from the changer or something like that.
I'm going to have to look into the USB interface, see if I can add a cable to my unit to let it play right off a USB stick. Had a rental that had that capability, kinda slick, but not fantastic, but beats leaving the ipod in the truck all the time. No, would have to buy a new unit to get USB direct. Oh well, maybe the next car.....
Discussion Starter · #17 ·
Available to me I have a touch, a fat short nano (found that one on bike path) and an older 30gig video. I know the touch will probably show but what about the other two. I wouldn't mind leaving the nano in the truck all the time...hell I found it in the bushes.
damn it DT, you are going to make me buy one of these
FYI GROM tech support just gave me this.
With the TEXT button you will have full text for MP3 files, partial text for WMA and no text for AAC or OGG files.
Ipod text will appear as well.
Discussion Starter · #19 ·
:lol: What can I say! Thanks for the info on the MP3 ect. I was holding my breath figuring it would work. I wish it would arrive....postal service is taking forever.
1 - 20 of 50 Posts
