1 - 4 of 4 Posts
Hi. Kindly assist. I want to locate my throttle position sensor. Is it different ftom the knock sensor?
Super Moderator
They are two completely different parts with completely different functions. The TPS is located on the throttle body. The knock sensor is screwed into the engine block on the front side. See diagram below.
Super Moderator
Got your PM. It's better to ask questions here in your thread though, so others can benefit from the info.
Here's a pic of the throttle body your engine has. It's been removed from the engine, of course. The TPS is that black plastic part, the one with the silver dot on it, and a screw on either side of it. You can't just simply swap it out, though, if yours is bad. There are some adjustments to perform after it's installed. I don't know the details of that for your engine.
1998 T100 SR5 2WD
Welcome to the forums! :)
What is it that yer trying to do with the TPS and/or knock sensors? ;)
1 - 4 of 4 Posts
