I'm overhauling the cv joint on my 94 Camry i4 and unhooked the ball joint to pull the steering knuckle out far enough for the driveshaft to come out of the knuckle. Well afterward the steerking knuckle lowered a bit and the tie rod outer end boot oozed out some grease. I am wondering if that grease oozing out means the boot is bad, or just that the end is at a bad angle for the moment? The tie rod end appears to be fine otherwise. What's your experience with this?
Thanks in advance!
Thanks in advance!
