Hello Toyota Nation.
My almost 20 year old Tundra 4.7 failed today. It started normally but idled a bit wierd then shut down and failed to re-start during cranking. I could hear that the compression wasn't normal when it turned over. A random misfire and camshaft sensor code came up. After referring to a dealership it was determined that the timing belt failed by opening the passenger side cover just in front of the valve cover.
My main concern all along was the rubber timing belt which was changed twice before at 95 then again at 210 thousand kms. I currently have about 280 thousand on the old truck.
I'm curious if any other owners had a similiar type of timing belt failure and if it caused damages to pistons or valves? I want to fix this but my dilemma...is it worth it if there is further damage to cylinder and head parts.
Thanks for any reply.
