On my first and previous Toyota Cressida, I seemed to have learned from an experienced Toyota tech that the timing belts should be checked and re-tightened after ~10-20k miles. It appeared that the belts did loosen enough to notice - but I don't know why. (I don't think they are suppose to stretch at all?)
This was on a 6 cyl. DOHC engine so maybe the belt length would be much longer than on our 4 cyl Camry.
Nevertheless, I have never seen anyone mention the need to go back and check the Camry belt for proper tension after it has been installed.
So I take it that that we don't need to recheck and adjust timing belt tension again after installing the new timing belt?
I will mention that setting the tension on the Cressida (5MGE) was very similar in that it had a idler pulley with a spring and after turning the engine one would then tighten down the bolt so that the spring was out of the picture.
Another thing was on that engine, it was noticeable that the belt tightened up after the engine was up to operating temp so you needed to start off a bit loose. I think this was attributed to expansion of the large engine block (straight 6). Once I recall installing or re-tensioning a belt and it was just fine (quiet) at start up but after a few minutes the belt would start a noticeable whining noise. I had to go back in and loosen that belt a bit and the noise never appeared again and the belt worked fine for years.
Does the 5SFE timing belt do similar in getting tighter as the engine heats up?
For those of you who have done several timing belts, do you really let the spring set the tension or do you fudge on that spring just a bit by pushing on the pulley (one way or the other) to tweak it like you think it should be - tell the truth now...
