1 - 1 of 1 Posts
96 geo prizm
Hi all,
Just have a question. I recently found out my harmonic balancer needed replacing. The outer ring broke away from the inner rubber ring. Its probably due to age. Anyway I replaced it then I drove the car in the highway and found that it was vibrating a bit more. I thought it was probable that I melted the timing belt when I used a torch to heat the crank bolt. I just looked at the belt and it looks ok. I checked the timing marks and the way my engine timing is set is not the same as the pictures in the haynes manual.
Are my timing marks correct? its in my photo gallery. Just click the camera on the left side of my post
1 - 1 of 1 Posts
