1 - 6 of 6 Posts
Is this tire dangerous at this point on this 2011 Prius? I see this crack in it and it seems to have dropped PSI from 37 to 31 in a month while the other tires held 37 PSI. Not sure if it’s the crack or something else causing the pressure drop. Its the front tire.
I also attached a photo with the date code. Not sure how to read it. Does this code say these tires are from 2016?
Tire Wheel Automotive tire Synthetic rubber Tread
Tire Wheel Automotive tire Synthetic rubber Light
Thanks
thank you.
Which tires wold you recommend for a 2011 Prius? The back two tires are maybe 4 years and 20k miles old but are of two different brands. Should I replace all 4 tires?
All 4 is not a bad idea. Get any of the known name brands (Goodyear, Michelin, Bridgestone, Continental etc.), you should be much safer than what you have now. I have an '10 corolla, with tire size similar to yours 195/65R15. I am currently on General Altimax RT43 tires. I think Continental owns General now.
1 - 6 of 6 Posts
