09 Trix, 2.4 XR
Tire pressures right now Front 36... Back 35.5
I used Snow tires during the winter months, mounted on rims, without TPMS
I did a tire change over 1 month ago from winter to OEM tires.
With the OEM tires on, I tried to reset TPMS, disconnect the battery, read the manual,follow the reset instruction, and the tire light still there.
I am wondering if by rotating the tires (back to front) will it makes the TPMS light stay on?
here are my reset procedure
confirm tire pressure 32psi all around
I did turn my ignition on , hold the reset button and counted for 1001 1002 1003 and then turn back to the off ignition position.. no dice
reset the tire pressure to 23 psi.. do the reset procedure,
pump it back up to 32 psi and redo the reset procedures..
still no dice.. what should I do..
