1 - 7 of 7 Posts
I just ran into a problem with TPMS. Had new tires put on and now the TPMS system is messed up. Took it to the dealership and three of sensors are damaged and not working.
The tire place is going to cover any expenses and are being very sincere about the issue.
Typically the sensor is integrated with your valve stem. You will notice that your valve stem is metal vs. rubber.
When you remove the valve the sensor will fall inside the tire. If you remove your tires first you risk damaging the sensor with the tire removal tools.
There are aftermarket sensors that wrap around the center of the wheel like a huge screw clamp.
1 - 7 of 7 Posts
