FYI - Air pressure should be checked when the tires are cold for accurate readings. What I do is to check the air pressure at home and if I need to add air, I pump it up at home before I drive the car anywhere.Thanks. I mean where can I air the tires? Does the gas station do this? Or I should drive to the garage? How much will they charge me for airing the tires normally?
