1 - 5 of 5 Posts
G
I used to have to reset the tire pressure warning light on my 2000 Sienna
every time I took it to a dealer for service (oil change & tire rotation).
Ever since I stopped taking it to dealer for service, I no longer getting
the warning lights after tire rotation.
So did I do anything wrong during tire rotation that damaged the tire
pressure sensors? I sometimes clean the brakes using brake cleaner when
rotating tires. Could the brake cleaner damage the sensors?
Should some warning lights go off if the sensors are damaged?
I do want the warning light working properly.
Thanks for any info!
G
Discussion Starter · #2 ·
Correct me if I am wrong but wouldn't an under inflated tire (smaller
circumference) have to rotate faster to keep up with the other ones?
Jack G
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:[email protected]
> "ZR" <[email protected]> wrote in message
> news:eek:[email protected]
> I believe that the 2000 Sienna uses an indirect method of detecting low
> tire pressure. Instead of having an air pressure sensor mounted on the
> valve stem, an indirect method detects low tire pressure by detecting a
> difference in wheel rotational speed through the antilock brake system
> (ABS) wheel speed sensors. An under-inflated tire will rotate more slowly
> than the rest of the tires, and if the computer detects this condition, it
> will illuminate the warning light.
> I don't know why rotating tires would turn on the warning light, and
> rotating tires yourself or cleaning the brakes should not damage the wheel
> speed sensors. The ABS system does a self-diagnostic check when the
> vehicle is first started and move the first 10 feet. If a wheel speed
> sensor were damaged, the ABS warning light would illuminate.
> Ray O
> (correct punctuation to reply)
G
Discussion Starter · #3 ·
"Jack G" <[email protected]> wrote in message
> Jack G
Oops! I stand corrected!
Ray O
G
Discussion Starter · #4 ·
> Ray O
Great! That's a relieve. I do seem to remember one or more tire would be
flatter after the dealer rotated the tires and I had to inflate them. May be
they deflated or inflated some of the tires but forgot to do the same on all
tires.
Thanks!
G
Discussion Starter · #5 ·
>>>rotation).
>>> getting the warning lights after tire rotation.
>> slowly than the rest of the tires, and if the computer detects this
>> condition, it will illuminate the warning light.
>> wheel speed sensors. The ABS system does a self-diagnostic check when
>> the vehicle is first started and move the first 10 feet. If a wheel
>> speed sensor were damaged, the ABS warning light would illuminate.
>> Ray O
> be they deflated or inflated some of the tires but forgot to do the same
> on all tires.
> Thanks!
If one or more tires are underinflated relative to the other tires, the low
tire pressure warning would illuminate. It sounds like your low tire
pressure warning system is functioning properly.
Ray O
1 - 5 of 5 Posts
