1 - 5 of 5 Posts
OlDsChOoLeR
hello all.
I have a 2002 Tacoma prerunner with a factory lift kit on it.
the stock 15" wheels are visually small in the gaping fender. Not to mention i have 37k miles on them and they are balding quickly.
Im in the market for some new tires.
I want to know what a bigger all terrain tire I can throw on there with out having balancing and rubbing problems.
the factory size tire I believe is a 225/75-15
a guy at Discount Tire suggested a 30 x 9.5 x 15
is he correct???
any help or opionions?
ALSO: any good tacoma forums out there????
thanks, Luke
I just put a set of 265-75 x 16" Firestone Destination M/Ts on my 2003 PreRunner (X-tra cab w/V6). They're mounted on the factory 16" alloy wheels and the truck is at stock height. I have no interference issues. Full turn lock-to-lock with out rubbing, even over good sized bumps in the trail. However, I don't think you can go any bigger in diameter without a lift kit. With the V6 I notice only a slight decrease in acceleration (obviously due to a gearing change and more mass). With the stock issued BFG Rugged Trail tires (265-70 x 16) the truck handled like a car......poor turn-in (squishy side walls), poor traction off-hwy. Anyway, I'm running 39psi (front) and 37psi (rear) with the new Firestone M/Ts and I'm surprised that these tires are as quiet as they are, compared to say the BFG M/Ts. Truck handles much better now and has max traction in the dirt. These tires were rated the best M/T tire on the market. Priced from around $140.00 to $160.00 each, depending on the store. Oh! And they look very happening!!!
Just my 2 cents worth.
Sleeping While Awake
1 - 5 of 5 Posts
