1 - 9 of 9 Posts
1995 LE
yo guys, i have some 215-45-17 tires on my 17x7 rims with a 95 Camry LE. i have an opportunity to get some 225-45-17 for cheap, but i remember hearing somewhere that the 225's will rub on a Camry with stock Shocks. does anyone have any idea or insight?
thanks
The Other White Meat
Holden Apollo
that depends on wheel offset.
jack up both a front and rear corner and see if you got an extra 5mm of room between the strut and the guard sides.
not hard.
TN Pussy Man
Camry
^ werd- as long as your offset's not too high, then you should be fine
lot of us actually run 225's - I have 225/45/17s for winter and they're perfectly fine
'96 Camry XLE
My 205's rub slightly in the rear (have 3mm spacers), but it has a high offset. So like they said, depends on offset.
Turbo S2000 FTMFW
2005 Honda S2000
i have 225/45's with no rubbing whatsoever.
TN Pussy Man
Camry
wow...what offset are your running? 48, 50?
'96 Camry XLE
50. Gen 5 XLE V6 rims (of which 2 are bent). Fuck Town Fair Tire!
1 - 9 of 9 Posts
