guys,
I've got 96 camry, 4 cylinder w/105k. I went to bleed and flush all 4 brakes. While bleeding the driver's side rear (rear drum) the wheel cylinder suddenly burst while my assistant was pumping the brakes. I went ahead and replaced the wheel cylinder and the same thing occurred with the new cylinder (i.e. after around 5 pumps to the peddle to build pressure to bleed, the wheel cylinder piston shot out more than would be expected, followed by a mist of brake fluid. any idea what the hell I'm doing to toast these cylinders? thanks!
